Old 03-14-2008, 08:49 AM
www.4Crawler.com has a page on fuel relay problems. See if Roger can't fix you up.
KDěRCH
Old 03-15-2008, 09:49 PM
6772trucks 6772trucks is offline
I found the AM1 and AM 2 fuses. I tested and all is good. I traced the wire from the fuel pump up to the inside underneath the passenger seat. I disconnected the plug under the seat and crank the engine and still no power at either the white or the blue wire.
What is the chances of a bad relay regardless if all test came out good?
Hopefully I can get a chance to get out and try and trace more wire.
Old 03-20-2008, 10:28 PM
I have replaced all relays to include the circuit open relay and still nothing. I also replace the pump and still not getting anything. Out of options?? I can spray starting fluid into the throttle body and get it to fire up for a few secs then cuts out after the starting fluid is gone. I have ran a direct power from anothr sorce to the old fuel pump prior to changing and I can get it to fire up but would not stay running. Acts as it was not getting enough fuel pressue. Would the cold start valve have anything to do with this?
Thanks
