Old 03-19-2008, 08:48 AM
Letting it rattle around some more, I think what doesn't seem right is the claims of fuel economy increase. Going from 22MPG to 60MPG? Uh, yeah, if that was possible why wouldn't the manufacturers be all over it? Probably the vast conspiracy to keep us all suckling at the teet of crude oil. OK, there might be some of that, but at least one manufacturer would buck the system and try to corner the market. Color me very skeptical. There just isn't that much energy left in the exhaust, certainly not enough to see 300% increases in economy. Even an old 22R-E or 3FE uses an O2 sensor and is trying to stay close to stoichiometric balance and our engines already do some of this with EGR, which helps with burned HC.
Old 03-19-2008, 09:40 AM
Chris's Avatar
Chris Chris is offline
You're right on there, if it worked to the degree mentioned manufacturers would be all over it. This whole conspiracy to keep fuel economy under wraps by the powers that be has been around since forever. It's fun to think about but so is thinking Jimmy Hoffa is alive and well.
Old 03-19-2008, 11:43 AM
Letting it rattle around some more, I think what doesn't seem right is the claims of fuel economy increase. Going from 22MPG to 60MPG?....Color me very skeptical. There just isn't that much energy left in the exhaust, certainly not enough to see 300% increases in economy.
Agreed, which is why I want to watch from the sidelines to see what happens and get some hard data and hopefully real life unbiased testing on an 80. I certainly wouldn't mind being a test subject (assuming someone can tell me this won't cause my engine to melt down) but I don't plan to send them $1K for some snake oil technology...
That would be if Robbie got "certified" and proved this stuff really worked
Old 03-19-2008, 12:01 PM
If you assume that the amount of H2 produced is not really significant, then I don't think you'll do anything that the ECU and ignition advance won't be able to deal with. My guess is the main immediate concern would be not passing the tailpipe emissions tests anymore. While the catalytic converter prefers a slightly lean condition for the oxidation reactions, if you lean out too much the reductions won't be balanced. At a slightly rich condition, the NOx reduction is favored and if you are abnormally lean then you might not reduce enough NOx and that could fail your test. I'd have guessed on an 80 series with an O2 sensor after the cat that the ECU would run rich to keep the reactions balanced and so that would compensate out any MPG gains you might get from introducing hydrogen into the intake. A single O2 sensor system would just be shooting for 14.7~14.8 stoichiometry and so adding fuel into the intake might make the ECU dial back the fuel injectors, that seems logical I guess.
The unburned HC oxidation
Attachment 8325
Carbon Monoxide oxidation
Attachment 8326
Nitrogen reduction (this is the NOx)
Attachment 8327
Old 03-19-2008, 12:19 PM
Dave, I don't understand half of what you post but it makes fascinating reading non the less
On the ECU issue, if I read correctly (in the thread on MUD or at the website), their is a piggy backed ECU somewhere in the mix that may handle some of the issues I think you are talking about.
Old 03-19-2008, 12:55 PM
They aren't gonna undo thermodynamics with a piggy backed box, so all they can do is remap the fuel profile to compensate for anything their gizmo might do. Now that I think about that, I wonder if that's the key, their chip. Putting a hyper-economy aggressive fuel map into the ECU would make your MPG skyrocket, although it would be like driving a 6,000 lbs Hilux with a 22R-E... S L O W. That could be the trick, you bolt on this $1,000 box that doesn't really do all that much, but with it you have to put this chip in to make it work. All the tricks are in the chip. It's like a distraction, watch this hand, watch this hand, as the other hand is liberating your of your wallet.
Old 03-19-2008, 07:36 PM
Originally Posted by powderpig View Post
I know If I got better Fuel milage from the cruiser, I would drive it more than I do now. For now, it is the Saab.
Interesting - Both Robbie Antonsen (master mechanic and master wheeler) and Mark Whatley (master mechanic and master wheeler) wheel Land Cruisers and drive Saabs.
FWIW, I get a moving weighted average of 16 MPG in my 1971 FJ40 and 15 MPG in my 1978 FJ45. My wife says I'm a freak because I keep track of this stuuf. She has no idea what she gets in her 2001 VW bug with 1.8 turbo gasser. My best guess is around 21 MPG (she has a lead foot with the turbo).
Old 03-19-2008, 07:41 PM
Actually, that is not what the EGR is for. The purpose of the EGR is to reduce combustion temps, thus reducing NxOx. At our elevation, this is not an issue and all the EGR does is rob us of performance and fuel economy.
Old 03-19-2008, 08:26 PM
calphi27's Avatar
calphi27 calphi27 is offline
Same here I wish I was a master mechanic though.
1990 FJ62 aka -HOGMAULER- (OME Med-SR-ARB Bull Bar-SROR Sliders)
Old 05-18-2008, 10:57 PM
Jeff, looks like he got it installed. Good thing he wore his extra thick flame suit http://forum.ih8mud.com/80-series-te...-increase.html
:popcorn:
