Old 03-20-2008, 12:12 PM
Stephen, that stick & screw method is genious.. I'm going to do that one next time. I'm often amazed at the stuff you know... and here I was thinking I wouldn't learn something today.
Old 03-20-2008, 04:45 PM
Some great ideas people! I'll give it shot this weekend and hope that I don't screw anything up..........
Old 03-20-2008, 05:06 PM
I've always used two long straight edges. Bungie cord them to the outside of the wheel parallel to the ground. They need to be longer than the diameter of the tire! Measure the distance between the rear and the front lines and adjust accordingly. At this distance of separation you want about 1/8" difference.
Colorado Trail Patrol
Stay on the Trail!
Old 03-21-2008, 09:07 AM
Uncle Ben's bungee corded straight edges on the tires do the same thing as the toe plates (as long as you don't have bodywork in the way.)
KD0FDS
Stephen
Old 03-21-2008, 09:33 AM
When your talking about separation and distance. I'm assuming your meaning the distance apart from the front of the tires, from the distance between the back of tires?
Old 03-21-2008, 09:53 AM
A-B= 1/4" or so..
Old 03-21-2008, 01:20 PM
Why not just measure from the same spot inside the front of the tire, and do the back side at the same location?
Old 03-21-2008, 01:52 PM
Radial tires often have wavy sidewalls so the best thing is off the bead seat of the rim (great tool Rude Boy!) of make sure you have a good average cross section (thus the straight edge).
Stay on the Trail!
Old 03-28-2008, 12:17 AM
beatdown83fj60's Avatar
beatdown83fj60 beatdown83fj60 is offline
If you don't get it figured out I know that Evergreen Automotive in Evergreen (duh) has a nice alignment rack and they work on more than the average vehicle. 303-674-0214. They will definitely be able to figure out a crossover setup .
Old 03-28-2008, 07:33 AM
78landcruiser 78landcruiser is offline
Here's how I drew my lines:
http://www.youtube.com/watch?v=zjoXHN2-PRM
Not perfectly accurate, but fairly so, and I was happy with the outcome.
Read more about my 78 FJ40 rebuild here:
http://78landcruiser.blogspot.com/
