Old 03-28-2008, 09:00 AM
Ended up taken it to Lakewood Alignment on Allison St.......$75.00, but figured the cost of tires was worth it.......
Old 03-28-2008, 01:44 PM
What did the shop conclude - was it way out of whack? Were camber/caster ok?
Old 03-28-2008, 08:54 PM
The total toe was -0.98 degrees when I brougth it in(Specified Range -0.01 to 0.39 degrees). They were able to set it at 0.23 degrees. So, yes it was way out of wack causing the inside of the tires to wear. Cross Camber and Caster were within specs!
