Old 03-21-2008, 09:43 PM
Rock Dog Rock Dog is offline
Default keeping up with the Mall Cruiser's
I have been lurkin on the threads about 80's with great interest, and although Nakman is definitely an innovator when it come to mods I think Mike has shown us all how much he puts into every project no matter what it is. I also appreaciate the way he and Kevin have documented some of the mods recently with pointer's to mud threads.
What i need to find out is:
- if either Kevin and Mike still have the 1n4001 diode's for the "autoup" mod. I would like to give it a shot.
- more about the Temp Guage mod. would probably change a few of the lights at the sametime (not as many as Mike, but a few).
- more info about the rear seat recline that Nakman was talking about
- what is the blue fan clusth mod?
- sunroof drain mod ?
- details about the Starter contacts i always hear people complaining about
- what are people using for extended breathers on these beasts?
- lift recommendations and gears (pro/cons)
C'mon Uncle Ben i feel like a newbie all over again Share some of that vast research i know you have been doing ....
your humble student "Rock Hopper"
Old 03-21-2008, 10:48 PM
Romer Romer is offline
Diff Breathers so when you go through water the diffs don't fill with water based on them being so low
http://forum.ih8mud.com/10092-post7.html
Starter Contacts. The starter contacts when they get old can short on keeping your strating cranking and the only way to shut it off is to pull the battery cable, So a lot of people do the PM to spend $25 on new contacts and a plunger
http://www.george4wd.taskled.com/starter.html
First read this on Lifts and then you can evaluate OME or Slee or the few others that are out there
http://forum.ih8mud.com/80-series-te...ssion-faq.html
The sunroof drains can get clogged so some clean the drains, some mod the hoses. I personally haven't done anything here. You know when you need it when your ceiling leaks after a good rain
The seat recliner mod
http://forum.ih8mud.com/80-series-te...gear-swap.html
Temp Gauge Mod
http://forum.ih8mud.com/80-series-te...ification.html
Auto window up
http://forum.ih8mud.com/80-series-te...indow-mod.html
Don't forget this one
http://forum.ih8mud.com/80-series-te...ells-good.html
All can be found in the 80 FAQ on Mud
http://forum.ih8mud.com/80-series-te...ft-review.html
Old 03-21-2008, 11:01 PM
Thanks Ken !!!
These are great! I have so much to learn about the new rig, but really like driving it.
I was having problems searching on Mud earlier, thought it might be the firewall at work.
I guess i need to find my old mud passwordand quitjust lurking without signing on...
Old 03-21-2008, 11:29 PM
Best way to search on Mud is to click search in the masthead and the select Advanced (Not the google one on the bootom of the search window)
Select the 80 section. Type your keywords in and then select in title only first to get fewer hits, then expand if needed.
BTW- You will notice that a lot of the FAQs were put together either by or with the help of Rising Sun Club Members. Robbie and Christo both helped with the OME lift item. nakman is famous for his snakster
Old 03-21-2008, 11:36 PM
Since you have a supercharger, you may wish to add a second temp gauge rather than the temp gauge mod. You will get hotter than a stock truck and have less time to react so a more accurate gauge is recommended
I then installed a boost gauge and temp gauge following this mod http://forum.ih8mud.com/80-series-te...d-install.html
The temp sender is installed on a boss right near the distributor
http://forum.ih8mud.com/80-series-te...-question.html
Old 03-22-2008, 12:20 AM
Just FYI on these...An 80s mod day has been discussed for some time in the future to complete both of these...Somewhere there is a thread on this and the general consensus is we all wanted to wait for warmer weather.
Not sure if this will happen before or after CM08 but last I heard, between Kevin and Mike they have enough diodes to complete the mod on all of the 80s in the club
Old 03-22-2008, 08:17 AM
sleeoffroad's Avatar
I am pretty sure that truck has a lift on it already
Christo Slee
KØSLE
www.sleeoffroad.com
Old 03-22-2008, 09:27 AM
It does have a 2.5" lift and 33" tires. Christo, you are probably more familiar with the truck than just about anyone, and it is a great truck. I actually need to come out to see you for some new items for her.
Old 03-22-2008, 09:30 AM
[quote=Romer;67397]Since you have a supercharger, you may wish to add a second temp gauge rather than the temp gauge mod. You will get hotter than a stock truck and have less time to react so a more accurate gauge is recommended
Thanks Ken for the pointers,
I think having a seperate guage does make sense I really liked the pillar guages.... in addition it would also be nice to correct the original guage to eliminate the "dead spot"...
Old 03-22-2008, 10:35 AM
[quote=Rock Dog;67415]
Having the temp gauge being true linear is more than accurate enough for a tractor engine!
KØUBN
