Old 03-28-2008, 11:12 PM
sawzall....not looking to cut the hanger off...i still need it to be functional and cut off wheel wouldn't have gotten in there either.
pretty sure that i couldn't rent a plasma cutter for the $16 that an air chisel cost. was actually wanting to buy the industrial $80 one, but nobody in town had any decent ones...welcome to denver, the biggest little city in the world.
awful lot of work for 1 1/2" (no comments from the peanut gallery)
Old 03-28-2008, 11:27 PM
I wasn't suggesting cutting the frame in two.....just cut the rivet head off!
Old 03-29-2008, 10:38 PM
heck, i'm not that talented.
productive day today. got the passenger side done, mounted the socket for the trailer wiring (even with a crappy hole saw), got leds in the light switch and under the dash light, found a crap connector at the water temp sender, then another really crap connection right after that and fixed both of those, pulled the sway bar, cleaned it, and lengthened the links to match the lift, figured out why my choke won't work anymore (apparently a 9" air cleaner won't clear it without a little lift), put in a new (junkyard) hood pull handle, and fixed the crappy oem ground on the front marker lights. dang i'm tired.
