Old 04-01-2008, 09:18 AM
PabloCruise's Avatar
Awesome write-up Matt! Now, where'd you get the majic SST?
There is one floating around on MUD that ToyLand4x4 lends out. He lent it to me, I lent it to Matt, and I am shipping it to Salt Lake today to lend out again. Still not done w/ my knuckles!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 04-02-2008, 04:21 PM
Thanks for the comments guys, I only did this because it started leaking so soon after my first rebuild - on the first time I reused the shims like most people do. So we'll see if this lasts any longer.
There are two shim thicknesses:
43233-60010 is 0.2mm (0.008") and
43234-60010 is 0.5mm (0.020")
I started with the following (For the Driver's Side):
Driver's Side Bottom: 0.040" (2 x 0.020")
Driver's Side Top: 0.039" (2 x 0.020")
The total adjusting shim thickness I needed was 2.5mm (0.098")
Driver's. Side Bottom Needed: 1.2mm (0.046") (0.006" off from what I had)
Driver's. Side Top Needed: 1.3mm (0.052") (0.013" off from what I had)
Because there are only two sizes available I had to get as close as possible, so:
Driver's. Side Bottom Used: 1.2mm (0.048") (2 x 0.020" + 1 x 0.008") (0.002" off from req'd)
Driver's. Side Top Used: 1.0mm (0.040") (2 x 0.020", determined by preload) (0.012" off from req'd)
I started with the following (For the Passenger's Side):
Pass. Side Bottom: 0.048" (2 x 0.020" + 1 x 0.008")
Pass. Side Top: 0.048" (2 x 0.020" + 1 x 0.008")
The total adjusting shim thickness I needed was 2.4mm (0.095")
Pass. Side Bottom Needed: 1.6mm (0.063") (0.015" off from what I had)
Pass. Side Top Needed: 0.8mm (0.032") (0.016" off from what I had)
*As you can see this one was offset by quite a bit*
Pass. Side Bottom Used: 1.5mm (0.060") (3 x 0.020") (0.003" off from req'd)
Pass. Side Top Used: 0.9mm (0.036") (1 x 0.020" + 2 x 0.008") (0.004" off from req'd)
HTH
Rising Sun Bio
1996 FZJ80 1FZ-FE factory lockers + Safari intercooled turbo, CDL switch, cup holder, Metric TLC leather, heated seats, JDM switches, Puma OBA. Warn M12000 waiting for a bumper.
