Old 04-22-2008, 10:20 AM
Well, I finally figured that if I am going to bump these things on, then I wouldn't mind the high beams being on as well. So, I simply tapped the high beams and now I am done with it... Man, those things get HOT!
After all my wiring and routing last night I only had one fire up! I did a bunch of checking and figured out one of the bulbs was bad. So, I ordered a new 100w bulb and had them throw in two of the 130w bulbs That is 230w of goodness! I had a full 12+ Volts at the lamp end of the leads...
I need to double check and see if I can hack the 130w bulbs on the wiring I ran.
On a different note, the Hellas have 18-20ga wire coming off the lamp... MAYBE! Why do they call for heavier wiring on the install, doesn't the wire size determine how much power can get to the lamp? I was a little confused, I ran separate 16ga wire to each lamp but I was curious why it doesn't "bottle-neck" the power when it steps down to a smaller size?
Just curious! Oh and Dave, I would like to eventually run option #4
Old 04-22-2008, 12:35 PM
yeah, i used to turn them on just to stand in front of them when it was cold out.
sweet that you got them going, they are some sweet lights eh?
Old 04-22-2008, 05:08 PM
Yeah, right now it is like a bright wink!
