Old 01-18-2006, 09:42 AM
Default Bead Blasting
I have an unobtanium part that I would like to paint. Before I can do that I need to blast it. I would really like to bead blast it vs sand blast so I don't warp or pit the metal. If someone has a bead blast cabinet on the south end of town that I could use briefly sat I would really appreciate it.
Old 01-18-2006, 11:20 AM
Wes,
I have a buddy that has a cabinet that you could probably borrow. I don't know what kind of media he has. He lives right down the street from me (and he's a Cruiserhead; he's just not much of a "joiner").
Old 01-18-2006, 12:58 PM
powderpig's Avatar
Maybe try Christo. I think he is using Beads in His cabinet, but do not really know for sure. Not on the south side, but still maybe close enough. robbie
Old 01-18-2006, 04:22 PM
74fj40's Avatar
74fj40 74fj40 is offline
how big is it? i know you probably dont want to pay tohave it done, but if its a small peice, then try media blast, they charge per minute....
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 01-18-2006, 04:37 PM
it's about the size of a bezel... :p
Where is this place max... Is it a DIY?
Old 01-18-2006, 04:40 PM
sleeoffroad's Avatar
Wes, it will fit in my cabinet, but I run a pretty agressive aluminum oxide. How thin is the metal and what is on it that you need to get off?
Old 01-18-2006, 04:42 PM
You might try some aircraft finish remover (commercial paint/varnish remover) first. The paint on bezels is oven baked and tough to remove....fought with that before!
Old 01-18-2006, 04:44 PM
I have sand blasted all 3 of my 40 series bezels with no ill effects. I wouldn't worry about what the media is.
Old 01-18-2006, 04:50 PM
I figured with all the curves of a bezel it's be a royal PITA to try and use stripper.
It's a pretty solid early 40 bezel. I just didn't want to use a real abrasive media and risk screwing it up... The OEM stamped ones are hard to come by and money...
Old 01-18-2006, 05:46 PM
Did Santa bring you a stamped bezel for Christmas?
