Old 04-26-2008, 08:01 PM
Default R151F detent springs same as T-case?
Are the detent springs on the R151F tranny the same as the ones on the gear driven transfer cases?
My truck will occasionally work it's way out of 2nd gear on the trail (with lots of load/unload/load/unload motion it will silently slip out of gear under no load) I suspect worn out tranny, stiff boot and worn out detent springs.
I have a couple of extra heavy duty detent springs for the T-cases. Will they fit?
KD0FDS
Stephen
