Old 05-14-2008, 10:13 AM
Driveshaft.
KDěRCH
Old 05-14-2008, 10:24 AM
Romer Romer is offline
Sounds like to mucch grease in the shaft, not U joints. Common problem
http://forum.ih8mud.com/80-series-te...oting-faq.html
post 5 item 4
Old 05-14-2008, 10:45 AM
timmbuck2's Avatar
Hmm...I have not greased the shafts in months...and only added a little to 1 yesterday...I will go read the link, thanks Romer!
T
* 00 LC
* 99 Saab Convertible
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 05-14-2008, 10:57 AM
Could still be U joints. Use the full link to troubleshoot including removing shafts to isolate
Old 05-14-2008, 11:08 AM
Nay's Avatar
Nay Nay is offline
I would take your rear driveshaft off and have balance checked. That sounds exactly like a rear driveshaft on an 80 that got nudged out of balance. I have found that enough candy caning of the rear shaft will show up as an increasing vibration at those low speeds.
Old 05-14-2008, 11:36 AM
Definitely sounds like u-joint based on symptom description. Vibrating at a certain speed under a certain load (or opposite - when coasting) has always been the hallmark of every worn out u-joint I have ever had.
Old 05-14-2008, 11:44 AM
RockRunner's Avatar
I agree 100%. take the DS of and inspect the U joint of the truck. On the truck it can still seem to be good if it is just starting to go. Once it is badly worn it will squeal and vibrate at lower speeds too.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 05-14-2008, 12:08 PM
Just pull the driveshaft and have it checked for true, balance, and U-joint condition.
Englewood Driveshaft.
KDěRCH
Old 05-14-2008, 12:41 PM
TheBruiser TheBruiser is offline
It may sound funny... But especially since you mention the (possible) misfire at excelleration, and being more pronounced under load, you might just have bad spark or wire. I too have experienced vibration in my drivetrain that to my surprise was fixed by checking/replacing a plug wire. Just a thought.
Old 06-30-2008, 11:53 AM
timmbuck2's Avatar
Ends up being a bad u-joint on the front driveshaft. Looked fine the first couple of times I checked it out, but the noise has been getting worse so took a look and it is bad. Installed the CDL switch so I could remove the front DS. Took a look here on replacing the u-joint http://forum.ih8mud.com/80-series-te...your-80-a.html and not sure when I will have the time nor patience to tackle this. Will order up a new u-joint from Stevinson today, where would be good to replace it? Thanks.
T
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
