Old 06-30-2008, 11:56 AM
Rising Sun Webmaster
Englewood Driveshaft off South Broadway could do it for you.
It's not that hard to replace a U-Joint -- I did all four in my garage on a Saturday afternoon.
Old 06-30-2008, 11:58 AM
Romer Romer is offline
Just go to englewood drive shaft on south Broadway and the will rebuild and balance your drive shaft for about $200 including the U Joints. make sure they use Toyota and have them order from Burt asking for the RS club discount or you could go get them at Stevenson and drop them off. Balancing is important as well.
Old 07-02-2008, 11:31 AM
timmbuck2's Avatar
Should I replace both the spider and the flange yoke? the flange yoke is what is broken...at Stevinson it is about $120 with RS discount to get just 1 spider and flange yoke...
* 00 LC
* 99 Saab Convertible
* 76 Piggie
has a 2008 FJC
KDTIM
  #24
Old 07-02-2008, 04:09 PM
Does the spider (Toyota-ese for u-joint) turn freely on all 4 caps? Are the needle bearings all still intact? If it is OK, you could probably re-use it. It is a wear item, so it will eventually need to be replaced, but they do last a long time.
