Go Back   Rising Sun Member Forums > Toyota 4x4 > 4Wheeling and Event Staging Area > Rubithon 2008 planning
Old 05-16-2008, 06:51 AM
Convert's Avatar
Convert Convert is offline
How is the project going Dan?
It is back in the truck if things go right should be running this weekend
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KØVRT
Old 05-16-2008, 08:28 AM
Right awn! Good luck/skill with that!
KØUBN
Old 05-16-2008, 09:13 AM
Original Post:
http://www.risingsun4x4club.org/forum2/showthread.php?p=56803
  1. Sliders -Red_Chili Built
  2. Fixing and Herculining the rocker panels -Done (minus Herculining)
  3. Budbuilt cross member -Done
  4. Budbuilt IFS and engine skid -Done
  5. Marlin 4.7 t-case -Done!
  6. Ball Joint spacers (1.5" of front end lift and increased travel) -Done
  7. Ball Joints - Done
  8. Alignment -Done, but still slight left pull
  9. Shocks -Done
  10. Rebuild brakes -Done
  11. Replace rear spring and frame bushings and install greaseable shackles -Done (Not doing greaseable shackles until I rebuild the springs)
  12. Buy some spares -Mostly Done
  13. Replace O2, plug wires, ECT, TVV -Done (except Fuel Pressure Reg., that's gonna wait)
  14. Reinforce rear bumper -Done, Marlin Bumper
  15. 33x10.50 BFG MTs -Done
  16. Fixing up under dash wiring for accessories (it's a hodge-podge) -Not Done, just hacked in a fridge circuit
  17. Fridge -Done
  18. Total Fluidectomy -Still need to do an oil change, about it
  19. Build Fridge Mount -Engel Slide Lock bolted in
  20. Middle Skid/Cross Member -Holben Arts Built
  21. Hi-Lift mount on the ARB -Holben Arts Built
  22. Grease Drive shafts
  23. PACK!
Old 05-16-2008, 09:23 AM
Cool! Fun to see how much got done and what got done!
KØUBN
Old 05-18-2008, 08:42 PM
Convert's Avatar
Now that my truck is back on the road And runnin sweeeeet! I have reduced my list of Must Do To:
Finish 2nd fuse box install
Mount and balance new tires
Install on board shower
Fix the damn broken power antenna
Install IPOR skid plate
Pack and prepare some food Cant wait this is going to be a great run
Dan Reinmuth
71 FJ40 project
TLCA 13269
KØVRT
Old 05-18-2008, 11:03 PM
Romer Romer is offline
Excellent, Glad to hear your up and running again Dan.
Old 05-18-2008, 11:31 PM
Updated 6/8/2008
These things have been done:
• 4.88 gears (done. Precision gears)
• Fix front of sliders so they don't hit my new tires
(sliced at both ends and welded up courtesy of Mr. Green Machine)
• Lift of some sort: need more than I have now
(now rocking the Slee 4" lift)
• 315 tires (Mickey Thompson Baja MTZ Radials)
• Winch (used Warn M12000)
• New Redline synthetic gear oil in diffs and transfer case (not on original list)
• Head gasket service done by Powderpig (not on original list)
• buy and install synthetic winch rope (not on original list)
• install Slee electrical harness (already own)
• install Center Diff Lock switch (already own)
• install MAF upgrade (not on original list)
These are yet to do:
• install front and rear Slee adjustable panhard rods (own, need to install)
• install John Deere low beam lights (already own)
This might get done. If not, no big deal:
• install new speakers for stereo (already own: Infinitys)
• install rear overhead light (already own)
These just ain't gonna happen:
• Sub tank (someday)
• Drawers
• Fridge
Originally Posted by nakman
Old 05-22-2008, 07:49 PM
Convert's Avatar
Default Updated List
Mount and balance new tires Done
Install on board shower Bracket is built
Fix the damn broken power antenna Ordered
Install IPOR skid plate Installed
Install new front windshield gasket Have in hand
Go through tools and trail box figure out some sort of tie down system for eveything
Dan Reinmuth
71 FJ40 project
TLCA 13269
KØVRT
Old 05-22-2008, 09:23 PM
Tch2fly's Avatar
Tch2fly Tch2fly is offline
I still need to swap front control arms but I got a couple things done:
Installed Slee Tcase skid plate (replaced crossmember with an unmolested version, thanks to Corbet)
Modified my rear storage unit. It was too tall to have easy access to the Engel. It was also a good time to move one of my stereo amps from the side of the storage unit into the qtr panel to make room for an inverter (may not make the budget till after Rubithon)
I cut out one side dropped it down leaving enough room to hold 2 5-gal scepter cans
and installed a slide for the fridge.
Still waiting on some things to complete my "secret project"
Mike W.
Old 05-24-2008, 08:23 AM
mtncrsr mtncrsr is offline
I still trying to design a custom skid plate. What a complex 3-D project that has become.
I also am looking at upgrading my steering components with some from 4X4 Labs. We will see how the finances look for that one.
Lastly I have leak in the AC system that I need to track down and fix.
