Old 05-17-2008, 01:14 PM
mtncrsr mtncrsr is offline
Default Gear Lube for my 40
I know that there are a lot of different brands of gear lube out there and probably as many opinions on what is best. What do you guys suggest for diffs, tannys, and t-cases, Lucas, Redline, Purple Magic or whatever its called or something else. Also, what do you recommend for a viscosity or oil weight, 80W-90W, 85W-140W?
Old 05-17-2008, 01:43 PM
I used Redline 75W90 synthetic in my diffs and tcase recently. Seems like good stuff. You probably can't go wrong with any of the premium oils.
It's called Royal Purple, FYI.
Originally Posted by nakman
I like the Redline 75w-90 personally.
Old 05-17-2008, 08:23 PM
Thanks guys. Any suggestions as to a good place to purchase Redline in the Denver metro area?
Old 05-19-2008, 11:46 AM
I will argue that you may see more leaks with synthetic in an FJ40.
I have found that synth. gear oils in older trucks tend to leak where regular oils haven't. YMMV. I run regular old cheap 80w-90 from a 5 gal pail ($30+ at Advance Auto). It's not like my FJ40 is the 'high gas mileage rig of choice'. 75-90 would be fine, too, I'd think.
Old 05-19-2008, 12:05 PM
80w-90... regular old dino like steve said in a 5 gal bucket. If your running a lockrite or aussi 80-140w. No need to pay more for syn.
Old 05-19-2008, 12:15 PM
x3 what Steve and Wes said. I replace the oil often enough that synth wouldn't be worth the $. Plus it will likely cause leaks as mentioned. My transfer case also likes to pump the trans full of oil, so I'm always draining and refilling. Cheap 5 gallon bucket of stinky 80W90.
Old 05-19-2008, 12:25 PM
I have ARB's. Does that make a difference?
Old 05-19-2008, 12:29 PM
There's a fix for that. Did it 5 years ago on my 40, and have now forgotten the details. I think there is a seal that needs to be replaced between the transfer case and transmission. Did it when we put the Mark's gears in my transfer case.
Old 05-19-2008, 12:31 PM
Details in this thread (post 8). I went to 3R Racing because they answered the phone when I called them.
