Old 05-18-2008, 08:33 PM
Default What do you put in your parts washer?
Almost just like the title says - I know most of you put parts in there. I am wondering what cleaner you put in. I finally got around to cleaning up the parts washer I picked up from Ige and it is ready to be filled up with cleaner.
A follow-on question as well. Do you have to empty the cleaner out after each use to keep it from evaporating away?
Old 05-18-2008, 09:40 PM
I bought 5 gal of cleaner from murdochs. Even with the lid closed i've had alot evaporate. I've filtered it a couple times too. I just keep the lid down when it's not in use.
You could also mix your own. mineral spirits, diesel, kerosene etc.
The stuff safety kleen used to use in our parts washers at an old job was awesome. I might spring for it one day.
Old 05-18-2008, 10:00 PM
Just make sure the solvent you use is not chlorinated or you will have a tough time getting rid of it when you change it later! I buy my solvent from Bartkis Oil here in Boulder. Also do not be tempted to use low (thanks Jeff) flash point materials (Gasoline, diesel, kerosene, etc) or you will create a very nice bomb!
Old 05-19-2008, 09:28 AM
FWIW, the machine shop I worked at as a teenager used diesel fuel as a machining oil, cutting threads, vertical mill, etc.
KDRCH
Old 05-19-2008, 11:56 AM
Maddmatt Maddmatt is offline
Works good to keep your shovel clean when you're laying down hot asphalt too. That's a job I don't miss. Diesel - the miracle fuel!
Matt
1996 4Runner
Old 05-19-2008, 04:30 PM
And obviously lunch time beverages....that there filled in a few pieces of the puzzle Bill!
Old 05-19-2008, 06:20 PM
I forget whether it's Haynes or the FSM (I'm thinking probably FSM) that recommends diesel.
Personally, I use regular old mineral spirits, AKA paint thinner. High flash point, low vapor pressure, low toxicity, as inexpensive as it gets and cuts grease and grime better than most of the water based cleaners I've tried. Diesel and kerosene are similar, with the latter having a higher vapor pressure and a lower flash point. Gasoline has a rather low flash point and I wouldn't use it.
When I was a teenager and worked on a paint crew, an old hand showed me how safe paint thinner is by tossing his lit cigarette butt into it. It simply extinguished.
Old 05-19-2008, 07:22 PM
Diesel works very good out doors in an open container! Good for your hands too!
Old 12-22-2009, 08:05 PM
Mendocino's Avatar
I was at Marco's recently and he had Agitene in his HF parts tank. I have tried all kinds of enviro solvent solutions and was tired of them being ineffectual. I bought the Agitene today and WOW!; this stuff is expensive but it rocks.
It reminds me of being a gas station mechanic in 1980 using some carcinogenic solvent without gloves that worked too! I am so happy.
Jeff
Old 12-22-2009, 09:39 PM
diesel is the same...so is gas. it's the gas fumes that explode.
i used to pay for actual solvent, but it's up to about $45/gln now! so i just use diesel. works great, cheap, available anywhere.
