Old 05-23-2008, 10:49 PM
Default OEM Jack Resto
I disassembled, blasted, primed and painted the oem bottle jack. Some light lube and assembly. I still need to locate 1 - 8mmx1.25 phillips screw. The yellow is krylon tractor and implement paint in Old Equipment Yellow. Very hard to find paint. Turned out well though.
Old 05-24-2008, 01:28 AM
VERY nice
Do you have the jack handle/extension dealyo?
Old 05-24-2008, 06:01 AM
Where did you end up finding the paint? Did NAPA order it or did you convince Krylon to send it to you directly?
Old 05-24-2008, 06:04 AM
Very nice looking Wes. Good job!
Old 05-24-2008, 08:15 AM
Napa did finally get it. The one on county line and holly has 2 more cans.
I have to look around for the extensions. I don't think i have all the pieces for it.
Old 05-24-2008, 09:03 AM
Wes I have a factory jack hold down in a bag somewhere, I might have the handles too, I will give a look.
Drew
Old 05-24-2008, 11:00 PM
Funny - I sandblasted and primered about 4-5 of those for Mark Sobzack some years ago, he gave me one which I still have somewhere. Those are very cool and functional jacks. No need for fluid or seals, it's all mechanical screw threads.
Old 05-25-2008, 12:05 AM
Drew
x2 - One of the few things I kept from my '76. Not sure if there is a difference between what should be in a '66 vs. what was in a '76 though. I know how much of a purist Wes is
Old 05-25-2008, 08:58 AM
Wes - Is there anything you did/do when rebuilding a bottle jack to keep it functioning healthy? I've got the one that came with my 40; it lifts just fine, but the jack won't go back down without significant weight on it (or repeated blows with a hammer).
Old 05-25-2008, 10:28 AM
I'd take it apart and regrease it. It's pretty easy. There is a large cog wheel inside turned by the small one that has the loop on the outside. That's what gives it the power. Under the large cog wheel is 2 washers that house loose ball bearings. The large cog wheel is basically is a large screw. As it's turned it extends the piece that comes out of the jack. I'd pull it apart degrease and clean and then reassemble with some light grease. It could be really dry and slider piece doesn't want to fall when screwed back down. It could have some pitting too that's hanging it up. If it's missing the set screw for the loop that you turn it could also bind gears.
Use a good #3 phillips or an impact driver to loosen thos screws so they don't strip.
I should have taken some pics of the inner. I think UB has a 76ish jack from Maddmatt for me. I'll rebuild that one too and take more pics.
hth
