Old 05-27-2008, 12:31 PM
smileyboy's Avatar
smileyboy smileyboy is offline
Default OME low lift on FJ80-Party
I am planning on trying my first install this weekend. Is there any thing that I need to buy to make sure I have everything to install this?
I have the full low lift kit.
I also wanted to get some help from the community if possible. I can provide burgers and beer.
I figure posting here would be easier than posting on MUD.
thanks in advance.
Old 05-27-2008, 12:34 PM
timmbuck2's Avatar
Depends on what time, but I will make it if I am free!
T
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
Old 05-27-2008, 01:58 PM
Isn't "low lift" a bit of an oxymoron?
Make sure you spray all three rear shock bolts, today, with PB blaster. that's the one 17mm on the bottom, and the two 14mm bolts on top, that hold the plate up on the body. spray the front lower shock bolts as well.
To get the DS front shock on and off, I've found it's easiest to have one guy hold a wrench on the top nut, while another guy with strong arms twists the whole shock below- I've used a big pipe wrench on the shock to do this as well, which works great especially if you don't plan on keeping/selling the shocks you take off. this can be easier than finding the right wobble extension to get under the brake master. If you had a set of crow's feet sockets, this would be a cool opportunity to use one. Open your hood then look under the brake master at that bolt, then decide how best to turn it- that's the hardest bolt of the whole job.
Old 05-27-2008, 06:56 PM
smileyboy's Avatar
just changed my mind. I think I will do a 2.5 lift. Hehe the wife won't like that.
Old 05-27-2008, 10:58 PM
smileyboy's Avatar
Is this something I should be having installed by a shop?
Old 05-27-2008, 11:30 PM
It's not rocket science but it is also the suspension that you will be driving on at 70+mph. Read the articles on Slee's website and see what you think. If you have to ask, the answer is yes.. or at least maybe.
Old 05-28-2008, 02:24 AM
I had Slee install my OME lift...Well worth the $$ IMO but I also didn't have a clue at the time, I was having Slee cut the rear cross member to install the tow hitch for their bumper at the same time, and I was quickly running out of time for CM07 (seems to be a pattern for me).
Knowing what I know now, the install is pretty straight forward but it helps to have people helping that know what they are doing - they can make the install go very quick. Pressing in the caster correction bushings into the control arms might be the hardest part of the install , and it is probably not something you'll be able to do yourself. So, you either drive around with crappy caster until you get them installed or you take off the control arms and take them somewhere to have the bushings pressed in and hope they get them in there correctly. If you have a spare set of control arms handy to have the bushing pressed into ahead of time great. Otherwise your rig is down until you get this done. NOTE: This only applies to the OME 2.5" lift. If you stay with the stock height lift then I don't believe you need to do the bushings although maybe you get new ones with the lift anyway...
Old 05-28-2008, 11:22 PM
Jenny Cruiser's Avatar
Do it yourself. It's easier than you might think. I've got some vid of when I did mine I can put on DVD if you're interested in seeing what goes on. I didn't do the caster bushings though. It drove fine w/out them. They're still sitting in the plastic waiting for my next lift.
Old 05-29-2008, 09:36 AM
smileyboy's Avatar
Well, I'm asking cuz I've never done it one my own. Hence the post. Going to Pueblo next weekend. I may get Slee to do it if it I run out of time.
Old 05-29-2008, 10:38 AM
smileyboy's Avatar
bummer, Slee has a 2-3 week wait........
