Old 05-27-2008, 04:36 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Default Joint seal
Hi All,
I have a question about how to seal the joint between the back of the cowling and the body panel below the front windshield? There is what appears to be some kind of joint filler in there, but it's dried up and allowing moisture to leak into the truck (noticed it in the glovebox and passenger floor board).
Thanks!
LETSROLL
Old 05-27-2008, 05:04 PM
I've heard of people using 3m drip check successfully for that seam but I have not used it myself.
Old 05-27-2008, 05:30 PM
seam sealer...available at napa warehouse
Old 05-27-2008, 06:12 PM
LETSROLL's Avatar
Should I remove the old material first or just apply over it?
Old 05-27-2008, 07:45 PM
Rising Sun Webmaster
Prev.owner of my truck had filled the whole thing with caulk and painted over it.
Old 05-27-2008, 10:37 PM
3M seam sealer. To answer your question directly, remove all traces of the original seam sealer and apply to clean painted metal or bare clean metal. It's all in the prep.
Old 05-27-2008, 11:14 PM
EWheeler's Avatar
EWheeler EWheeler is offline
What would be the cons to just welding it?
Old 05-27-2008, 11:46 PM
For starters, never being able to fold down the windshield as Mr. Toyoda intended.
Old 05-28-2008, 07:22 AM
Like he said. Plus welding sheet metal is not for the faint hearted and still requires filler in most cases.
KDRCH
Old 05-28-2008, 07:41 AM
that shouldn't affect the windshield folding, it's well below where the w/s folds
but as mentioned, welding sheetmetal is not easy....burn through, warping among are the most common problems
