Old 06-17-2008, 02:27 PM
Beater's Avatar
Beater Beater is offline
Default ifs front axle - school me
ok - so how long does it REALLY take to do a cv axle on a runner or taco? Evidently the t100 is the same as a runner/taco, and I have a bad axle on this beast...
it's not liking the full lock right turns
j
Old 06-17-2008, 02:38 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Easy.
Remove ADD cap and snap ring holding the axle in.
Remove four bolts on lower ball joint (14mm)
Remove sway bar bolts (14mm deep) (both sides) on lower control arms,
Remove lower bolt for the shock (22mm?) and use a jack to push on the hub to lift the hub up and away from lower control arm (the spring tension is on the upper a arm),
Remove the (6, 17mm) nuts on the CV that connect it to the diff,
Slide the spindle out of the hub and you are home free my man
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 06-17-2008, 02:39 PM
Squishy!'s Avatar
Oh and feel free to pry down on the lower a-arm as needed
-Justin Morgan,
TLCA #23166
Old 06-17-2008, 03:32 PM
Beater's Avatar
ok - so same as every other fwd/awd. 2hours r/r?
Old 06-17-2008, 03:49 PM
Seldom Seen's Avatar
I've got it down to under an hour. B/4 you go tearing into it make sure that the sound you hear, at full steering lock, is NOT the the steering stops rubbing. If the plastic caps on the adjuster is worn through or missing, they make a hell of a noise esp. when hitting a bump at full lock.
Old 06-17-2008, 04:15 PM
Beater's Avatar
will do. the boot is trashed and gease is gone. rebuild at least.
j
Old 06-17-2008, 05:50 PM
New is more sure then, and not prohibitive if aftermarket or good boneyard is obtained.
KDěRCH
Old 06-18-2008, 08:41 AM
Squishy!'s Avatar
CVJ does great rebuilds. just give them your core. Burt uses them regularly
-Justin Morgan,
TLCA #23166
Old 01-12-2015, 08:03 PM
Originally Posted by Squishy! View Post
Easy.
Is the procedure above the same for a 91 4Runner?
Old 01-12-2015, 08:26 PM
Squishy!'s Avatar
Should be.
-Justin Morgan,
TLCA #23166
