Old 06-17-2008, 03:16 PM
Mendocino's Avatar
Default FJ40 replacement leaf springs
My right side springs are really sagging. I would like to:
a. replace all four springs with something that provides a 4" lift
b. do the low budget option and have them rearched (right side only).
So, which springs and from whom for option a?; or who in the Denver metro area rearches springs? I do have a BFH but would prefer to have someone do this that actually knows what they are doing.
Jeff
03 UZJ100 (2.5" OME/Slee suspension), Slee Step-Sliders, LEDs, cross drilled and slotted rotors by PowerStop, and some other goodies.
75 FJ40; 355 HP/405 FP torque/ fuel injected ZZ4; Snorkel, 700R4 tranny, Orion, ARBs F&R, armored, winch, ...; and now weighing in at 4370 lbs.
Old 06-17-2008, 04:59 PM
I have the Downey 4" lift springs on my 40. They are fairly inexpensive and I have no complaints. Also, take into consideration everything else you'll need to replace/add along with the springs: Extended brake lines, shims, U bolts, shackles, bushings, shocks. If you don't need the full 4 inches of lift, the OME 2.5" kit comes highly recommended by a lot people. Kurt at Cruiser Outfitters usually has a good price on the kit.
Old 06-17-2008, 05:16 PM
Denver Spring can rearch springs.
Old 06-18-2008, 12:04 AM
Mendocino's Avatar
Thanks Fellas.
Martin-I already have all the kit, but with saggy springs. I would prefer the rearch but need to remodel my garage/shop to get the 40 with a springover in the door.
SubZ-Thanks, that was exactly what I was looking for
Jeff
Old 06-19-2008, 12:41 AM
Possibly cheaper than a re-arch and much longer lasting is the home-brew 2-3" lift I run on my 71. It'll clear 33x10,5s and still has a comfortable ride. Costs about $120.
