Old 06-24-2008, 09:34 AM
Default electric locker help
factory 80 rear locker. correct me if i'm wrong, but with the shift collar locking bolt unhooked (so collar that slides on splines and shaft from actuator are not hooked together), when the switch is activated/deactivated, i should see the shaft move back and forth, correct?
Old 06-24-2008, 02:19 PM
Is the center diff locked?
Old 06-25-2008, 11:42 AM
no. does that have to be locked first? dang buttons
Old 06-25-2008, 11:46 AM
Romer Romer is offline
The diff won't lock unless the center diff is locked either via the CDL button in high or the Tcase in Lo. You should see the orange light on the left side of your dash lights
