Old 07-05-2008, 10:08 PM
Default A/C Problems??
88 Pickup 22RE. Okay, after a year of not having my A/C on, I decided to recharge my system with R12. I did evacuate the system first! When I went to start my A/C the clutch started skipping, and smoke from the belt came up for a couple of seconds. After that the clutch started turning like normal, and still does operate like it should. However, I don't think the freon is circulating or the pump is not pumping. I don't know if this is because the clutch(or stater) burnt out and is not turning the pump? Or if it the pump itself?
Any thoughts?
Thanks,
CJ
C.J. Bowen
2015 Jeep Rubicon Hard Rock, 2000 Jeep Grand Cherokee
Old 07-07-2008, 08:29 PM
If anyone has a more detailed diagram of the A/C system, better than Chilton or Haynes??? Be a great help.
C.J. Bowen
Old 07-07-2008, 09:09 PM
May not be identical to your system, but if you look on the Rising Sun FTP server there's a PDF of the 1993 factory service manual. It would be similar in any case.
Old 07-07-2008, 09:19 PM
How do you get there? I'm thinking now that there may be some blockage. I don't know if you can reverse flow, or blow pressure through there?
C.J. Bowen
Old 07-07-2008, 09:29 PM
How to get to the RS FTP server:
http://risingsun4x4club.org/forum2/s...ead.php?t=3099
Attached a few of the main diagnosis sections.
Old 07-08-2008, 07:58 AM
Beater's Avatar
Beater Beater is offline
I would suspect you lost a bearing in the compressor. Personally, after running through the diag in the fsm, you could go used, but I would do reman, w/clutch. The bad news is that you will probably need to do the receiver dryer and flush the rest of the system. Don't forget to change out/clean the filter screen in line, downstream. MOST likely, when you lost your compressor, some pieces fragged and clogged it up.
just a hunch, and probably wrong..
j
john (johnny) henley
Old 07-08-2008, 08:06 AM
Black death is bad juju for AC, or so I hear.
These boys can fix you up:
www.ackits.com
KDěRCH
Old 07-08-2008, 11:02 AM
www.ackits.com
That's a good site for replacing the A/C system. I think I'm going to take it down and pay for a diagonis. Just too many possibilities?? But I'm thinking something is clogging the system. I do see some slight fluid moving through the glass, but nothing consistent.
C.J. Bowen
Old 07-08-2008, 11:25 AM
They are very helpful over the phone too. Also good for piece parts, not just entire systems. Local diagnosis is probably a fine idea too though not free.
KDěRCH
