  #31
Old 09-13-2008, 09:48 PM
60wag 60wag is online now
So I'm finally back in 4 wheel drive. I got the diff reassembled and installed and after 20 miles, so far, so good. No noise, no leaks. Hopefully its the last time I get to see the inside of the rear end. It was a pain to do but was quite educational - way more difficult than a simple ARB install. I had to reshim the pinion and the carrier bearings to get the thing in spec. The pic below is the original case with the cracked flange.
