Old 02-06-2006, 10:05 PM
IanB's Avatar
IanB IanB is offline
Default Anyone have a 4" pipe cutter?
Anyone have a 4" pipe cutter? If not I'll just go rent one tommorow.
1976 FJ-40
2001 UZJ-100
Old 02-06-2006, 10:09 PM
Beater's Avatar
Beater Beater is offline
yes, but it's pretty ****ty. I have a band saw and chop saw that will do as well. or is this a in the house plumbing job?
Old 02-06-2006, 10:12 PM
Go to Harbor Freight, Tool king, Tool Zone or ???? and just buy a cheapo. You will want to mark the threads so you only cut 1/4" anyway. I borrowed one last time I did it....next time I'll buy. If you plan on using it more than a couple times buy a Ridgid or similer higher quality. If it will only be used once or twice a year or every other year support Tiwanese slave labor.
Old 02-06-2006, 10:37 PM
IanB's Avatar
Ugh, a Ridgid is like $300 for a 2"-4".
1976 FJ-40
2001 UZJ-100
Old 02-06-2006, 10:45 PM
Happy birthday IAN!!
Old 02-07-2006, 08:00 AM
Beater's Avatar
I bought a cheapie, and the damn wheel was done in in one cut, and this was on scd40 pipe!
since then, unless it's a supply line, I just cut it and clean with destructive power equipment.
I saved my plumbers arse by having a dual voltage plasma cutter. He cracked a main drain in the ground, and I cut it out so he could sleeve it. Don't ask how dangerous it is to cut a sewer line with plasma...
Old 02-07-2006, 08:14 AM
IanB's Avatar
This is for an axle Green, so I have cruder methods of cutting it but was hoping for a nice clean pipe cutter cut. I hear what you are saying about a cheapo, I think it would be throw away money. I will check the rental store.
By the way, the Guiness Drinker (its black, it must be Guiness) and the welder are way cool :fing:
...and thanks Wes!
1976 FJ-40
2001 UZJ-100
Old 02-07-2006, 09:03 AM
ebay 1
ebay 2 ***
ebay 3
ebay 4
....and there's more! Ebay 2 is like what I used before....worked great!
Edit: I just put a bid down on ebay 2. If I win it you can buy it from me for what I paid or just use it!
Old 02-07-2006, 09:36 AM
Beater's Avatar
I have cut axles in my band saw. where are you making the cut? pumpkin side or knuckle side?
If the housing is empty, we just put it on a stand and cut it off, as long as your far enough away from the backing plate or pumpkin.
Old 02-07-2006, 01:06 PM
IanB's Avatar
Ok I am keeping an eye on number 4.
Green - I actually want to cut the axle without cutting the inner sleeve, hence the pipe cutter.
1976 FJ-40
2001 UZJ-100
