Old 02-07-2006, 01:35 PM
Just use a grinder and don't go too deep....
Old 02-07-2006, 03:32 PM
Pipe cutters work very well and you can mark them so you only cut 1/4" deep, thus not cutting the inner sleeve. You then have a perfect round cut that helps keep camber correct and a little grinding in the groove you made sets up a perfect root weld base. :fing:
Old 02-07-2006, 04:00 PM
IanB's Avatar
IanB IanB is offline
Uhhhh, what he said! :fing:
1976 FJ-40
2001 UZJ-100
Old 02-07-2006, 04:11 PM
with too many of and a pipe cutter you end up with a swirily :lmao
I'm not knockin a big pipe cutter esp if I could use it in the future
Old 02-08-2006, 06:47 PM
IanB's Avatar
No luck renting one locally today, the cutting wheel is looking better and better.
1976 FJ-40
2001 UZJ-100
Old 02-08-2006, 07:49 PM
Beater's Avatar
Beater Beater is offline
try this trick. run the cut off wheel around like you're creating a perforation, then place a pipe/chain wrench and twist it off. you may have to heat a little, but it will keep you from touching the sleeve.
j
Old 02-08-2006, 07:51 PM
I won that one I bid on on Ebay so if you wait a week or so you can use it or buy it.
Old 02-09-2006, 10:30 PM
Kipper's Avatar
Kipper Kipper is offline
Administrator
Ian - get really good at this axle cutting... I have a 62 axle that will need it soon. Now to find someone with spring de-arching skills.
I have a friend in Tejas the used the same technique (big ass pipe cutter) and it worked great
Old 02-09-2006, 10:34 PM
Beater's Avatar
denver spring on brighton.
Old 02-10-2006, 08:19 AM
IanB's Avatar
Well I built a realy nice axle jig so I hope I find more axles to cut and turn
Uncle Ben - A week huh? Hmmm, might be worth the wait.
1976 FJ-40
2001 UZJ-100
