Old 07-24-2008, 11:32 AM
Default It's SO SIMPLE!
Stupid Autozone alternator has been giving me trouble since last summer! Belt squeals all the time (well not all the time, but a lot of the time) and especially at high loads! I had to get one though because my old one died on the way back from a 14er on a Sunday and NAPA was closed (Woodland Park in the afternoon). So I've put in about 4 since then (and BTW whoever decided it was a good idea to make an alternator change like a 3 hour job because you have to remove the distributor and the power steering pump should be kicked in the nuts), and EVERY ONE has been squealing the belt!
So last night I go out to retighten the belt a little (maybe it was loose somehow I figured) and the threads on the alternator housing stripped!
So I'm like - forget it! I'm going to NAPA! 3 hours later with a lifetime warranty alternator installed, I figured out why the others were making the belt squeal. The Autozone pulleys were plastic or something else with a smooth surface. The NAPA pulley is a cast aluminum one, so it has some roughness on it to hold the belt and keep it from slipping! Who at Autozone thought that THAT was a good idea!
Oy, hopefully this fixes that problem which I've been nursing for over a year because that stupid thing is so hard to remove!
Okay rant off...never buy Autozone electricals if you can avoid it, unfortunately Autozone has better store hours than NAPA... sigh
I know, some of you are going to tell me I should have gone with OEM Toyota - whatever I know leave me alone.
Old 07-24-2008, 11:46 AM
Disappointing
Cool. Nice fix.
OEM is nice, but so is Mean Green:
http://www.mean-green.com/products/alternator.html
Originally Posted by nakman
Old 07-24-2008, 11:47 AM
Should have bought an OEM alternator.
Old 07-24-2008, 11:50 AM
Romer Romer is offline
Hmm, I changed the alt several times on my 77FJ40 (Auro zone as well) and it was a quick 10 minute job, two wires and two bolts. Why is your 77 different?
Old 07-24-2008, 11:58 AM
i hate auto moan stuff. every alternator i have gotten from them i have had to replace on almost a yearly basis.
Old 07-24-2008, 12:13 PM
This is on the red truck BTW...
And also BTW I don't think there's a Toyota dealership in Woodland Park...
Old 07-24-2008, 12:16 PM
Not familiar with the 2WD, but I don't have to remove the distributor or PS pump to get the alternator off. Although, there is more space under a 4WD truck to work and half the operations are done sorta blind from below (sounds a lot like a honeymoon, oh never mind).
BTW, nothing wrong with NAPA IMO. The Toyota alternator is a remanufactured unit (at least the one I put on during the engine build was) and said the reman was done in Mexico, so the NAPA might be an improvement or at least essentially equivalent.
Old 07-24-2008, 12:17 PM
diesel runs without an alt-nator
Old 07-24-2008, 12:21 PM
So will a 22R-E for a while, at least until the battery gets to about 9V. Can you pop start a diesel?
Old 07-24-2008, 12:35 PM
sure.. just takes a little more pop at 400+ psi.
