Old 07-24-2008, 11:37 AM
sure.. just takes a little more pop at 400+ psi.
Gotcha, so a tug start from the mighty Hilux you're surely traveling with. :-) The lightweight Hilux is the safe backup, they can be pulled uphill with a totally electronics-free all terrain donkey for a pop start.
Old 07-24-2008, 11:40 AM
NAPA lifetime is a fine alternator. I coulda directed you to a site explaining how to rebuild it yourself for a whole lot less, but it would have been a whole lot more trouble.
There is quite a bit of variance in the difficulty in swapping 22RE alternators. Depends on the radiator hose routing.
KDěRCH
Old 07-24-2008, 11:46 AM
True on the variation. The FSM tells the mechanic to remove the radiator half of the lower coolant hose. Yeah, that's gonna happen.
Old 07-24-2008, 12:43 PM
I've push-started Wes' diesel before...
I can ALMOST remove it from below but the motor mounts and suspension stuff gets in the way. It sits below the dizzy and p/s pump in either case...
Old 07-24-2008, 10:39 PM
I HATE replacing alternators on 22REs. They are in a super-impossible place to get at (okay, not as bad a a chevy V6). And they are right under the P/S pump, which, if leaking, makes the alternators go out quick. Don't ask me how I know :-)
I can replace the alternator in any of my 40 series in under a half hour. Never tried it in a 60, but from the work I've done on 60s I'd guess double that. On my daughter's 85 runner it was about an hour. That's after you already figured out all the stuff you needed to get out of the way, and what you didn't.
I have had good luck with NAPA alternators for my Land Cruisers with F series engines, and also good luck with OEM. I have been pleasantly surprised to find that NAPA reman are built with OEM Nippon Denso cores.I have had VERY poor expereinces with both Autozone and with Checker alternators. Just my personal experience, YMMV.
