Old 07-29-2008, 01:41 PM
Where are you located specifically?
Old 07-29-2008, 01:43 PM
Romer Romer is offline
I had a similar problem and it was a clogged PCV.
Easy and simple to replace yourself
Still could be adjustment. Jeff Zepp is a great one with the 1F engines. Hopefully he will chime in here
Old 07-29-2008, 01:44 PM
Azrael's Avatar
Azrael Azrael is offline
I've actually got the 2F swapped in, or so the previous owner told me. I'll have to try the PCV.
SW Denver, near Federal and Evans.
Old 07-29-2008, 02:16 PM
Azrael's Avatar
OK, now I'm confused. It's definitely a 2F according to the block tag. When I checked SOR's diagrams, it looked like the PCV should come out the block near the firewall, above the starter. It looks like mine is up front under the #1 plug. Am I looking at the right thing here?
Old 07-29-2008, 05:17 PM
Azrael's Avatar
New PCV and tubing installed.
The engine seems to run a little smoother, but the problem still remains. It seems like it's not happening anymore when the truck is standing still, but still there when it's under load (actually moving the truck).
Old 07-29-2008, 05:37 PM
Looks like a weber carb. I remember reading on mud a lot of issues with those where people ditched them and went back to a stock carb.
Old 07-29-2008, 05:45 PM
Looking at the under-hood pic, seems like a lot of non-stock stuff happening. It's going to be hard to diagnose. I would go through the motions that Romer suggested, including the basics: Carb rebuild (or stock replacement), new plugs and wires, tune up...
It's an FJ40 (aka 30+ year old rig that will need lots of time, work and $ to own). Half the fun of owning an old rig is working on it. You're going to need to learn how to wrench on it yourself sooner or later, or else pay a load of money to take it into a specialist mechanic every time something comes up. Just being honest here.
Jump in and start asking questions as you go. Ih8MUD is a great resource too.
Old 07-29-2008, 05:50 PM
What kind of distributor is that? I would guess it should be vacuum advance and yet I don't see any vacuum tubes from the carb. There's some odd looking electrical wiring under there too. If the problem is while under load, might be more likely that it's a timing or firing issue.
Old 07-29-2008, 05:57 PM
Azrael's Avatar
The carb was rebuilt just before I bought it last month, and it looks like the plugs are new as well as distributor cap and wires, though I haven't pulled them off yet to check them. It was running fine when I bought it, this problem just started last week. I'm not sure what the actual distributor is, but I'll get a bett er pic of it in a bit.
Old 07-29-2008, 06:36 PM
Azrael's Avatar
Here's a better pic of the dist. if anyone can ID it off of that.
Also, what else in there are you seeing in there that seems aftermarket? Most of it seems pretty standard from what I've seen on others. As far as the wiring you mention, the light blue line at the top goes to the electric choke. The red wire running off the battery is a battery tender.
