Old 08-11-2008, 11:06 AM
FJBen's Avatar
FJBen FJBen is offline
Default Roof Rack questions
Looking at picking up a roof rack for the 80.
It's a used Con-ferr Porthole style...4x6' is the measurement.
Is that size going to work well with the 80? Thoughts on this being a decent cheap rack?
I was thinking about using the "groucho" feet for this if it's going to workout.
TLCA#15530
96 285's OME 's ride
Old 08-11-2008, 11:20 AM
Rock Dog Rock Dog is offline
Groucho's gutter mounts are awsome... Really beefy.
I was going to get them, but went with the aluminum African outback Rack that Christo sells. It is not cheap, but works out great
Old 08-11-2008, 11:38 AM
Groucho's Avatar
Groucho Groucho is offline
Decent rack, even better if you get a good deal.
I believe Convert (Dan) has one. Seems to be perfect. I homebuilt one that is 48"x80", I like it.
They are knock offs of the mounts that would have come stock with the rack you want to buy, so they would be perfect.
--Choose Wisely--
Old 08-11-2008, 11:52 AM
FJBen's Avatar
awesome, thanks for the answers. It's a pretty good price on the rack which is the reason I'm thinking about it. We always need more room.
I'll pm you some info so I can get the feet ready for the rack
TLCA#15530
Old 08-11-2008, 05:29 PM
Con-Ferr basket + Groucho mounts = good combination. It's not the lightest thing in the world, but definitely gets the job done....
Rubicon tested.
Old 08-12-2008, 09:30 AM
FJBen's Avatar
Awesome! and on the rare dark green cruiser
very cool. I'm hoping to pick it up this weekend. I definitely won't fit in the garage..but it will be nice for camping, as we are quickly running out of room.
TLCA#15530
Old 08-15-2008, 11:42 AM
FJBen's Avatar
Just a test looking last night. I have the groucho clamps...holy beefy!
TLCA#15530
Old 08-15-2008, 01:44 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
I don't like the rounded corners and lack of really good tiedown points (the ones on this rack's square bars slide side to side and the holes are not great to use. Attaching to a corner is almost impossible.). I also did not like the mesh floor on Tim's rack. Even well bolted it rattled. Also, the floor typically only attaches to the crossbars putting all the weight there and not distributing it on to the much stronger perimeter. But, given the cost of racks, at the right price its a lower cost alternative. Definitely use at least 6 gutter mounts. I had only 4 attached and tweaked the gutters when I launced into the river on the Outlaws run.
Old 08-15-2008, 03:18 PM
FJBen's Avatar
Good advice.
Currently I have 6 groucho clamps
It doesn't have a floor on it, so I"m thinking of options for that. I'm thinking aluminum rails running perpindicular to the crossbars. It won't be used a ton as I can't fit in the garage with it on.
I"m sure adding some tie down points will be really easy. Given the cost of this project as opposed to some other racks out there, I'd say this is a steal/no brainer. Of course if I were using it every weekend to expedition all over, I would definitely pony up for the nicer racks.
thanks for the tips...I was thinking of that expanded steel floor...now maybe not
TLCA#15530
Old 08-15-2008, 04:00 PM
Beater's Avatar
Beater Beater is offline
racks like that are not meant to be off/on/off/on/off... if your not being able to get it into the garage is an issue, well....
as for the floor, I had real good luck with plywood in my hardcore rack. less deflection than metal, easier to modify, blow holes in, add tie downs, etc etc etc
just a thought. I used 3/8ths ply
john (johnny) henley
