Old 08-20-2008, 04:19 PM
CardinalFJ60's Avatar
Default measuring shocks question
I've got 4 OME shocks to replace the ooollld Rancho 9000's on my 40. I've got about 2.5" lift on it. the current ranchos (front, PN999113) show collapsed at about 13.75" and extended at 20" from the spec sheet online. The OME when extended are 21".
I want to be sure I'm measuring correctly. I'm just measuring from the top of the eyelet to the bottom, that is, the entire length of the shock. is that right? or should I be measuring from the bottom of the eyelets for the length of the cylinder itself?
thanks!
Old 08-20-2008, 04:23 PM
I'd have assumed eye-to-eye length, but that's only a guess.
Old 08-20-2008, 05:39 PM
FJBen's Avatar
FJBen FJBen is offline
x2 thats how I always measured them.
TLCA#15530
96 285's OME 's ride
Old 08-20-2008, 05:40 PM
Default cool..
that's what I figured...just wanted to be sure the new ones aren't the wrong length.
Old 08-21-2008, 12:34 AM
are you changing shocks?
what are you doing with whatever is coming off?
Old 08-21-2008, 07:09 AM
Default was gonna have them bronzed
well, the Rancho 9000s are fairly old but quite classy. I might bronze them ...but heck...if you want them, we could 'talk'. I'm sure you'll like the proposal.
for a little background, the rest of the suspension is Rancho (rides like iron) and I'm trying to do something to help the ride a little. new leafs are a couple notchs down the project list at this point..
Old 08-21-2008, 05:54 PM
Did you take the Ranchos off and try driving it with nothin?
Old 08-21-2008, 07:38 PM
Default Not yet.
Just got back inside from squirtin' a little PBB on them. gonna be a weekend project. I think I will take it for a spin around the neighborhood...I didn't think about it, but now I sure will. Obviously, no harm as long as I keep it slow, eh?
those springs are STIFF, any chance I'd also smooth them out a little by driving w/o shocks. (please say yes.) I suppose I could also bend up those little tabs on the leafs someday. I've heard that helps. any-hoo...weekend here we come!
Old 08-21-2008, 08:21 PM
drive it without the shocks.
got anywhere to try to flex it out without them on?
if you feel ambitious, drive down, we'll take them off and go over the hill
BTW, Hidden Valley is supposed to be grated so i hear its quite mild right now.
no pucker factor right now
Old 08-22-2008, 09:25 AM
Shawn, I saw you driving south on Wadsworth this morning, right around 88th.. I was headed north. Couldn't tell if you took the shocks off though, did ya?
