Old 08-24-2008, 08:07 AM
Beater's Avatar
Beater Beater is offline
I have a beverly shear, hand held shears, snips, plasma and all that good stuff you are welcome to use with supervision (beer)...
16ga seems heavy, why not 20~22?
j
john (johnny) henley
Old 08-24-2008, 12:05 PM
16 gauge is what the factory used until late 1976, when they went to 18 gauge sheet metal (also coincided with using recycled steel, which is a subject of considerable debate as to whether it rusts faster). After looking at hundreds of rusted 40s over the years, I would say subjectively and anecdotally that the "later" rigs are almost always more rusted than the earlier ones.
Old 08-24-2008, 06:28 PM
lfd270ben's Avatar
lfd270ben lfd270ben is offline
I replaced mine it wasn't too bad. Go for #1 stop it before the back of the rig looks like swiss cheese
Ben
Colorado
1961 Dodge Power Wagon Town Cummmins 4BT, NV4500, NP205, Dana 60's
SOLD! 72' FJ40 little red 40 with some extras
2008 Dodge Ram Mega Cab Cummins
18 foot P&J flat bed
Old 01-19-2009, 10:35 PM
Default There's no turning back now...
Jeff Zepp - Did you use a sawzall to cut the outer two body mounts (the ones above the tail lights)? They're not exactly accessible if ya know what I mean....
Old 01-19-2009, 10:46 PM
Hi Matt,
IIRC, I used the air powered zip wheel (basically a 4" x 1/16" angle grinder) to cut the outer sheet metal, then tried to unbolt the body mount bolts. When they just twisted off, I then used the zip wheel to cut the bolts off, however a sawzall would have worked just as well once the outer skin was cut out of the way. A hot wrench (O-A torch) would have worked too, but mechanical cutting is usually cleaner.
Old 01-19-2009, 10:52 PM
Thanks Jeff. I've got the outer sheet metal cut away so that the mounts are exposed, but I can't quite get a tool in there to cut the nut head off. I'm going to try again tomorrow with my Dremel and see if I can get in there and cut the head off.
Old 01-20-2009, 11:36 PM
Hi Matt, instead of going for the nut, just go for a gap between (whatever's left of) the body mount and the frame cross member (bottom) or sill (top).
Old 01-21-2009, 12:19 PM
Way to jump in there, Matt! I need to do this same repair. I'll be watching your progress. Do you have a welder?
Old 01-21-2009, 03:43 PM
That would require planning and forethought. Naw - I'm much better at spontaneous destruction phase....
Jerry's getting me some new body mounts, so I should be able to get that far with the new sill before I have to address the body repair.
Old 01-25-2009, 12:34 PM
I say just make a bed of duct tape and fill it with bondo! It will be more rubust than what most people do to fix their 40.
Looks great Matt- if you get desperate and need me to tack up some steel for you and or weld in some new stuff, I'd be happy to help. I have a small break at the house too for small parts, mounts, corners... stuff like that.
Save all the old metal, I have found it helps when recreating the peices to fix it.
Have fun, while you are in a chopping mood, I say go for it all!
