Old 08-27-2008, 05:13 PM
Mendocino's Avatar
Default QSO from Vancouver BC tonight?
I'm in Vancouver, B.C. tonight and wanted to try connecting node to node on IRLP from Node 1000 to Node 3286 in Golden. Anyone around? There is a long ragchew on the local repeater going on at the moment so I can't call CQ now...
I could also try in the morning if someone wants to set up a Sked.
Jeff
03 UZJ100 (2.5" OME/Slee suspension), LEDs, cross drilled and slotted rotors by PowerStop, and some other goodies.
75 FJ40; 355 HP/405 FP torque/ fuel injected ZZ4; 700R4 tranny, Orion, ARBs F&R, armored, winch, ...; and now weighing in at 4370 lbs.
Old 08-27-2008, 06:08 PM
I can do 8:30-9 probably. If you need someone sooner I'm out. I still need to play with my tone settings. so 146.805 tone 186.2
Old 08-27-2008, 06:15 PM
Mendocino's Avatar
I think I will be at dinner then. I'm going to give it a go now...
Jeff
I can run out there for 5 min...
Old 08-27-2008, 06:18 PM
Mendocino's Avatar
Cool! I got in and called for you Wes but did not get you. the good news is that I got into the link this time! This is a much more satisfying result than in Australia.
Jeff
Old 08-27-2008, 06:29 PM
Huh.. I didn't hear you but I was definatly getting the repeater call sign
Old 08-27-2008, 06:42 PM
Mendocino's Avatar
Shall I try again? I'll do it now, no one is on the repeater.
3286 Node is in use...I'll monitor it online.
Jeff
Old 08-27-2008, 06:44 PM
I guess I gotta key in the irlp which I didn't do.. Some guy hopped on and key'd up las vegas to see what was happenin. Between trying to figure this out and trying to catch my kid at the end of the block a half dozen times i'm worn out. I still got some reading to do on this radio. It was fun though
Old 08-27-2008, 06:48 PM
Mendocino's Avatar
Wes,
You just have to listen for me calling you. I initiate the link from Vancouver. I have it figured now. If you can hit the repeater at wa2yzt we can QSO.
Jeff
Old 08-27-2008, 06:49 PM
I'll check now...
