Old 08-28-2008, 07:31 PM
Mendocino's Avatar
Howard, you can leave it at my place. I'd be very surprised if it was not driveable.
[edit] Sorry, I knew it was Howard.
Jeff
Old 08-28-2008, 07:48 PM
chtucker's Avatar
chtucker chtucker is offline
I was thinking of driving it somewhere.... AAA will tow 100 miles for free. Its 117 From Erie to Leadville according to mapquest...
chtucker= Christine & Howard Tucker.... gets confused all the time
Will talk more on Saturday..Don't forget to PM you address
Old 08-28-2008, 07:56 PM
powderpig's Avatar
I would do a compression test to see if the head gasket is gone between 5/6. I have not seen a cam go on these engines yet. Does not mean it can. I am currently in Vermont and not able to look at anything until next week.
When doing a compression test with all the spark plugs out, if you hear a slight compression squeek when you get compression on the guage and the guage reads lower then the rest of the cylinders(1-4) then you may have the gasket gone between the two cylinder. Any how good luck and I will check in when I can
