Old 02-13-2006, 10:01 PM
IanB's Avatar
IanB IanB is offline
Default Bolt on gear puller, might be a bearing puller
I need the kind of gear puller that I can bolt to my t-case to yank it away from the tranny. Its tighter than a (graphic metaphor deleted)! Anyone have one I can borrow for an hour?
1976 FJ-40
2001 UZJ-100
Old 02-13-2006, 10:08 PM
I think I have just what the doctor ordered....you gonna be home tomorrow?
Old 02-13-2006, 10:12 PM
IanB's Avatar
Yeah all day till 4, gone Wed and Thurs.
If you swing by I can pull it on the spot, will take maybe 5 minutes. You rule :fing:
1976 FJ-40
2001 UZJ-100
Old 02-14-2006, 10:28 AM
Even after you borrow Kevin's I suggest getting yourself a couple of pullers to have around. My favorite is the big 7 ton two jaw Craftsman, good for everything from t-case to pitman arms.
Old 02-14-2006, 10:30 AM
IanB's Avatar
I have 3 pullers, none of them bolt on however. Hmmm, this may justify a trip to Sears though....
1976 FJ-40
2001 UZJ-100
Old 02-14-2006, 10:36 AM
The 2 jaw doesn't bolt on, the jaws can grab inside or outside depending on which way you put them on. For the t-case, you orient them so they grab the inside edges of the hole where the tranny output shaft sticks through, and put the center onto the indent in the end of the shaft.
