Notices
Old 09-07-2008, 10:00 AM
InsanityIsBorn InsanityIsBorn is offline
Default 1st gear pops out
So I went for the maiden off-roading trip in my cruiser with new manual transmission and transfer case yesterday. Worked GREAT! other than two small problems. One was the clutch slave cylinder seems to leak which made it hard to shift occasionally. The other is the one I need help with. When I was going down several steep declines, I would have it in 4LO and 1st gear. I would get going along down the slope and I couldn't figure out when it woould happen, but it would pop out of gear and I would have to hit the brakes a bit and it would slide a bit (very sketchy in a few places). What could cause this to happen? How can I fix this?
Thanks for the help
Kiel
Old 09-08-2008, 07:29 AM
I am a mini guy so take what I say with a grain of salt. Possible causes (with a new tranny, assuming it was rebuilt? Still #3 applies):
1) Body contacting shifter under certain flex conditions. You mentioned only going downhill. The drivetrain shifts a bit.
2) Shifter seat wear.
3) Tranny has excessive play in bearings, or longitudinal clearances (C clip retainers on the main shaft) were not as tight as they should be.
4) Engagement ring (shift collar) retainers are worn.
KDRCH
Old 09-08-2008, 07:39 AM
Hate to say it but Chili speaks truth! For some reason first gear is either not engaging all the way of the mainshaft bearings are worn enough to cause the shaft to "wriggle" it out of gear. Definitely more than a "small" problem as that could be life threatening!
Colorado Trail Patrol
Stay on the Trail!
Old 09-08-2008, 08:25 AM
Chris's Avatar
Chris Chris is offline
Kiel, as I mentioned elsewhere, adjust the linkage.
Old 09-08-2008, 08:29 AM
Is this a "three on the tree" Cruiser?
Stay on the Trail!
Old 09-08-2008, 09:59 AM
Chris's Avatar
I had the exact same problem with my new 5 speed after install, adjusted the TC linkage and all's been fine since.
Old 09-08-2008, 10:51 AM
Now I'm really confused....is it his tranny or T-case popping out?
Stay on the Trail!
Old 09-08-2008, 11:13 AM
Chris's Avatar
Good point, Kiel doesn't really say but since it was so similar to my experience I made the leap to TCase.
Old 09-08-2008, 11:18 AM
Same story on T-case except it doesn't have syncros. Either like Chris states, the linkage is worn or out of adjustment or the output/lower shaft bearings are toast or the retainer is loose.
Stay on the Trail!
Old 09-10-2008, 11:34 PM
It is the transmission that is popping out of gear. But only in that exact instance: going downhill, in 4LO in 1st gear.
