Old 09-08-2008, 08:31 AM
treerootCO's Avatar
Event Coordinator
Default FZJ80 tech - heater not hot
As the cooler mornings have moved in, I have noticed the heater is not hot. I have yet to determine if the engine temp is related and/or the valve isn't working. On hot days with the A/C on for a bit, I can get the gauge to climb and the air coming from the vents is hot. On cool days like this morning, the gauge barely climbs, about 1/8" of an inch up from hot, with the temp gauge mod. Both front and rear heaters seem to blow cold air. I will dig into it at lunch, just looking for the known issues/gotchas that most 80 owners already know about. Thanks in advance.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 09-08-2008, 08:33 AM
Since it's both front and rear heaters I would suspect the hot water control valve on the firewall behind the engine.
KØUBN
Old 09-08-2008, 09:41 AM
The thermostat would be high on my list of things to check. Either use your hands or a IR thermometer and check the differential between your heater core feed hoses, and check the upper and lower radiator hoses, etc.
Old 09-08-2008, 10:52 AM
He stated that the engine temps were normal....that pretty much rules out T-stat being the problem.
KØUBN
Old 09-09-2008, 08:39 AM
treerootCO's Avatar
Event Coordinator
I suspected the valve, just needed options in case the valve wasn't to blame. Went out this morning and gave her a tug and....POP! Works flawlessly now
www.root45.com
TLCA #14133
Old 09-09-2008, 09:08 AM
KØUBN
Old 09-09-2008, 10:00 AM
I'm having the same issue with my FJ60. Is there a comparable valve I can check?
Old 09-09-2008, 10:03 AM
yes.. it's on the firewall. it's a 3 way connection iirc. A little wire from the control panel moves the valve open or closed.
WØREK
