Old 10-02-2008, 09:00 AM
ATLR ATLR is offline
Subazli why didn't you call me?? When you do a head gasket you raise the compression and you may have some blow by ( oil passing the rings ) I have seen it take care of it self in time but you may just have to keep adding oil. I for get did you cut the head? If so the compression went up a lot.
Old 10-02-2008, 09:19 AM
I remember you guys warned me about that, and I'm pretty sure that's what happening, I was just making sure. If I get sick of adding oil or something else happens don't worry Jesse, I will definitely be calling you
I have to get some stuff back to you still, so I'll be swinging by one of these days anyway...
Thanks for everything you've helped me with so far!
