Old 09-09-2008, 10:57 PM
Default 80 Series Starting Issues...
So the 's 80 sometimes doesn't want to start...Not a slow start but a turn the key and just a click type of no start...
It looks like Romer went through the same thing recently on Sarah's LX and the symptoms were identical other than the heat. So, I figured I would start where Ken ended up and check the NSS (neutral safety switch) first. That thing is a PITA to get off btw. I guess you could take out the front drive shaft to gain more room to work but I prefer contorting, scraping, banging, etc. my arms and hands on crap
Anyway, I don't think the NSS is my issue. I even went so far as to pull the locking tab and pop out one of the starter wires and it looked great. Guess my next step is to rebuild the starter although I really figured it was going to be the NSS because the truck has always started right up, never giving the typical indications you'd expect as the starter contacts get worn. I had already checked the obvious things (battery connections, cable at the starter, etc.) before pulling the NSS.
Any other thoughts before I break out the impact wrench and get busy on pulling the starter?
Pics...The white goop is whatever Toyota puts on there I guess and it looked clean.
Old 09-10-2008, 12:58 AM
Shark Bait's Avatar
Jeff, I went straight for the starter contacts on mine a while back. No more starting issues. I should add I also cleaned up the battery terminals & clamps at the same time. But the contacts were pretty worn.
'11 Tacoma, '12 GX460
Old 09-10-2008, 01:35 AM
Rising Sun Webmaster
If you're getting a click, then I agree with Mr. Shark Bait.
Old 09-10-2008, 06:55 AM
Romer Romer is offline
That connector doesnt look good to me. Did you try cleaning it, having someone wiggle the connector while you try and start it. I heard the click when it turned out to be that connector. It was a soft click though, not click click click which would be the starter
Old 09-10-2008, 09:06 AM
FJBen's Avatar
FJBen FJBen is offline
When my starter contacts went, it was only 1 click. not multiple. I'd go right for the starter contacts as well. Fairly cheap/easy and you know it's done and off the list.
TLCA#15530
96 285's OME 's ride
Old 09-10-2008, 12:56 PM
You don't think the connector looks good?? Compared to your picture on MUD I thought mine looked great, basically brand new. The grayish color isn't corrosion, it is (I'm assuming) Toyota dielectric grease and it looks brand new.
Yep, just the 1 click. 1 out of every 4-5 tries it'll start right up and then click. I've got the parts (like everything else I've had them for over a year ) so it'll only cost me the time to replace them at this point.
On a side note I got a good glimpse of the PHH on the 80 and I'm thinking that I probably better go ahead and replace that as well - I'll snap some pictures tonight for those out there interested in seeing it
I guess I'll find out this time around how much coolant leaks out when you don't drain it all out first.
Old 09-10-2008, 09:05 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Joe at Slee did my starter before CM. I was having the click symptoms. Problem solved.
Old 09-10-2008, 11:48 PM
Didn't have much time to work on it tonight but I got the starter out (thank God for air tools ) so I'll rebuild it tomorrow night.
In the mean time I got a much better look at the PHH and I'm thinking it needs to go. What do you guys think? I'm wondering...any of you ever change out the PHH without draining the coolant and if so, did it make a HUGE mess or just trickle out?
I don't how folks change the PHH without taking out the starter...
Old 09-11-2008, 08:14 AM
74fj40's Avatar
74fj40 74fj40 is offline
Pull the solenoid out and apart and clean up that disc thats in there, and depending you might even be able to just flip it over. Every time you start your car that disc gets a little more corroded, and doesnt make a good connection when you try and start it.
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 09-11-2008, 04:15 PM
Whatever drains out you'll replace with new stuff... so you're either not going to make a mess, or you're going to get a clean garage floor and some new coolant. win-win!
