Old 09-17-2008, 11:21 PM
Rogue Leader's Avatar
Rogue Leader Rogue Leader is offline
Default Stripped Wheel Spacer
Long story short, did a brake job on a friends accord and over tightened 2 lug nuts. when he tried to remove them they snapped the lug bolt off. I removed the wheel and started into the spacer and one of those bolts stripped. Any ideas on how to remove a recessed bolt? I tried to dremel it down to fit a smaller socket but that didn't work. Weld on a nut to the face of the bolt?
TODO ES POSIBLE, NADA ES SEGUNDO
MACINNES CLAN
Well we allready got one (holy grail)
I fart in your general direction
SEAN JONES KD0DHU
Fighting fire in the last frontier.
Old 09-18-2008, 12:17 AM
Sacrifice a cheap socket that is a tad too small. Drive it on the bolt with a BFH then with luck it will come out. Welding a nut on it might work if you can get to it good enough to get a good stitch or two on it.
Colorado Trail Patrol
Stay on the Trail!
Old 09-18-2008, 09:30 AM
vice grips on the remaining threaded side of the bolt. Unscrew it until you are close, then hack saw off the part you boogered up with the channel locks. Move vice grips to the regular bolt end and finish unscrewing it from the spacer.
KD0FDS
Stephen
Old 09-19-2008, 12:50 PM
Heating the areas around the bolt can help expand the female threads so it can turn easier.
