Old 10-05-2008, 02:37 PM
CBone's Avatar
CBone CBone is offline
Send a message via Yahoo to CBone
Default fj60 Transfer Case--Idiot Move--Looking for Help
I posted this thread over on Mud, but thought I would embarass myself locally and see if you all have any ideas:
So, there I was changing all the fluids and tuning up my new to me 1985 Fj60. I'm not much of a mechanic and was excited as all about having my new project LC to learn on. Changed the diffs, tranny, and crankcase without a glitch. Feeling good about myself I proceeded to tackle the transfer case, perhaps in a bit of a hurry as the kitchen pass ran out at noon. Putting in my last quart of oil in the tranfer case I accidently let about a 2" piece of plastic tube drop inside. The tube was originally on the end of the quart top, but it slid off. I tried filling the diff, thinking the piece would float to the top and I could somehow get it out--couldn't find it. Then drained it thinking it might come to the bottom--no luck either.
Am I screwed. Are my adventures as a wanna-be mechanic about to end? What have I done and any suggestions on how to fix would be greatly appreciated.
Thanks in advance.
2013 4 Door Tacoma (locked, lifted and loaded with essential accoutrements for adventure)
FWC on it's back as often as possible
TLCA#11073
Old 10-05-2008, 03:17 PM
you're toast!!!
no really, try to keep flushing it out by cycling your fluid, even though it's a pain to do.
then maybe try to see if you can hook it somehow thru the drain hole.
not sure if it's really an issue if it's just left in there.
hope it works out for ya
Old 10-05-2008, 03:19 PM
easy.. Take off the pto cover on the side.. you should be able to fish it out. It's only like 6 bolts and it's on the driver side. If you can't find it drain the fluid and fish it out. You can then put the gear oil back in.
congrats on a 60.. pics?
Old 10-05-2008, 03:28 PM
CBone's Avatar
Thanks for the ideas. The PTO cover seems to come off pretty easily, so I'll try to fish it out that way. Yeah, I need to get some pics posted, but decided to spend the morning wrenching, as opposed to snapping a few pics or even writing up the minutes from last week's meeting. I'll get around to the pics and the minutes sometime this week.
TLCA#11073
Old 10-06-2008, 01:32 PM
Mine's in peices now, if you want to take a look at what it looks like inside. I'd remove the PTO cover and try and get at it.
Old 10-06-2008, 01:39 PM
I would try to retrieve it from the PTO cover. If you can't get it then don't sweat it as it will not break anything if it gets caught in the cogs. Most likely it will just sit on the bottom of the case indefinitely causing no issues at all. I bet you might be able to see it and get a hold of it with a pick from the drain plug hole too.
Old 10-06-2008, 05:36 PM
Metal vs. plastic? I say the metal wins
Old 10-06-2008, 05:55 PM
CBone's Avatar
no concerns with the fluid heating up from the spinning of the gears, causing the plastic to soften and wrap around anything? Of course, I'm gonna try to fish it out, but if I can't find it, from what I'm reading, it may be all right to go ahead and not worry about it.
TLCA#11073
Old 10-06-2008, 11:19 PM
Man, this sounds familiar. I am master of turning a one-hour job into a three-hour job. Good luck!
Originally Posted by nakman
Old 10-07-2008, 10:27 AM
CBone's Avatar
Thanks Matt, it's good to know others started out at the lower end of the learning curve as well.
TLCA#11073
