Old 10-06-2008, 05:31 PM
Originally Posted by Romer View Post
Thanks Robbie. You see any reason this would help with an intermittant clutch slip? When you say away from the bracket, in what direction, towards the firewall or towards the radiator?
don't know if runner's are the same as an 80, but if so, they go sideways.
Old 10-06-2008, 07:20 PM
Mine doesn't!
Old 10-06-2008, 07:43 PM
Romer Romer is offline
They did go sideways and 2 of the three cables were real loose. The Haynes manual says the cable for the tranny should be taught. I tightened it up and Rachel will drive it a bit and so how it responds. My quick drive showed no issues, but it has been real intermittant. Supposedly from the Yota Tech thread (and Robbie's post), this cable determines the pressure for the clutch internal to the transmission. I hope that's all it was.
It was a 14MM on the 4runner.
