Old 10-06-2008, 07:35 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Default Hot ARB Bulbar Indicator lights
I just replaced my ARB Bulbar indicator light housings with shiny new ones thanks to Kurt at Cruiser Outfitters. I do not want them to suffer the same fate as the old ones - death by overheating. Any suggestions for a cooler bulb? My concern with LED is that they will not shine forward since the light is in sideways. Is there a lower wattage 1156 size incandescent?
Old 10-06-2008, 08:35 PM
chtucker's Avatar
chtucker chtucker is offline
http://usaled.com/?mainURL=/store/ca...wer_Bulbs.html
I have had really good luck with these guys..all of my plow trucks are running them to reduce power consumption... Only halogens are the headlights.. everything else is from these guys.
Old 10-07-2008, 10:56 AM
sno bored's Avatar
sno bored sno bored is offline
Use a #67 bulb. And while you're at it check out this mod. Takes about 1/2 hour to do, and I think it's pretty cool. http://forum.ih8mud.com/80-series-te...o-mod-vid.html
Old 10-07-2008, 02:24 PM
Ditto...a year and a half and no melted lenses here
P.S. when I read the thread title I thought maybe someone might have stolen your lenses...
Old 10-07-2008, 02:42 PM
treerootCO's Avatar
I like this guy's mod: http://forum.ih8mud.com/80-series-te...ignal-mod.html
I have these and like them: http://autolumination.com/1156_1157.htm
This is the 67 style: http://autolumination.com/otherleds.htm
1157 vs 67 but you can see if my 1157s are bright enough for you.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 10-07-2008, 04:54 PM
Any problems with the turn signal flashers using LED's? I've seen with the Tacomas that the LED's draw so little current that the flasher thinks the bulb is out.
Old 10-08-2008, 07:28 PM
Inukshuk's Avatar
Thanks guys! I will go find a #67 bulb for short term and look at the flasher mod later - I like it.
Old 10-09-2008, 08:58 AM
treerootCO's Avatar
CustomTacos should have the info we need but their search is not working at the moment.
http://www.tacomaterritory.com/forum...ad.php?t=29189
Here is the schematic if you wanted it. This mod does not work on the 95 FZJ80 flashers
www.root45.com
TLCA #14133
Old 10-14-2008, 07:50 PM
treerootCO's Avatar
fixed
http://forum.ih8mud.com/80-series-te...ml#post3746848
www.root45.com
TLCA #14133
Old 10-14-2008, 10:45 PM
Inukshuk's Avatar
wow.....
