Old 10-10-2008, 05:54 PM
Default 80 control arm?
first off, i'm guessing the rear control arm bolt isn't supposed to be shouldered, am i correct?
reason i pulled it is i get a hideous "oh crap my front end is going to fall off " clunk when i hit deep cracks/bumps in the road. first thought was maybe i didn't get my spindles tight enough when i rebuilt the front end, so i jacked up the front end and tried to wiggle the tires. they were fine.
then i crawled underneath and tried to wiggle track rod, sway bar, and the welded rod that goes across to where the track rod is bolted and they were tight, so i guessed the control arm bushings might be bad so i pulled one side. they look fine (rear is a little dry rotted, but not torn or anything. how do they look to you gurus?
also, in an attempt to fix the leaks on the ford, i replaced two questionable hoses under the turbo intake and when i pulled the intake, i found this written on the hump hoses. if you need to know where to position the clamps, you should take your rig to a shop
Old 10-10-2008, 06:11 PM
I think I'd replace the back bushings -- looks like crap. I thought all the bolts were shouldered.
Originally Posted by nakman
Old 10-11-2008, 01:05 AM
Nay's Avatar
Nay Nay is offline
Bolt looks good, it's probably the OME bushings, those things don't hold up well to serious wheeling.
Old 10-11-2008, 10:35 AM
Beater's Avatar
Beater Beater is offline
yep. your eyes will not be able to detect the slop that will make noise in a urethane bushing. bolts are shouldered. re-place them all, should take about 3 hours, with the right press tools and a HF press. Also check the panhard bushing. often overlooked, and will klunk on both load and unload, as it is stressed heavily on flex.
Does anyone remember who I gave my kustom press tools too????
I must say this is my LEAST favorite automotive job ever. worse than doing a tranny on your back, or a tranny service on a rover. (2.5 hour book job WITH a porta-power)
j
john (johnny) henley
Old 10-11-2008, 02:42 PM
On the front, the nuts have splines on the back side. On the back, the splines are on the shoulder of the bolt. Not sure about the back one, but the front ones should be replaced when you are doing service -- otherwise they will loosen just from daily driving.
Old 10-11-2008, 05:10 PM
i'm referring to the smaller shoulder up near the top.
Old 10-11-2008, 05:11 PM
how do you tell if they're worn
Old 10-11-2008, 05:31 PM
Beater's Avatar
bulging, looseness of the inner shell, both on the bolt and or urethane side. IMHO, urethane only ever lasts about 2-3 years if you wheel them. They do come out REAL easy though.
Old 10-11-2008, 07:00 PM
Bikeman Bikeman is offline
I would replace the bushings with slee's blue polyester bushings. They should last longer than the urethane, and replace the back one with factories.
FWIW, I have had 3 sets of control arms on my truck, and have never had the bolts loosen up when torqued properly.
Mike
2001 Honda XR400 with goodies
Old 10-12-2008, 09:49 AM
Beater's Avatar
blue loc-tite. nuff said
rtv works also, but not as well.
