Old 10-13-2008, 08:57 AM
Default Running cold
My engine has been having a hard time getting up to operating temperature since before Cruise Moab and I can't figure it out. I just put a new t-stat, o-ring and gasket in and it's a little better but not much
Before I search endless threads on MUD for other solutions, does anybody have any thoughts? I need HEAT for the Spooky Night Run!
Rising Sun Bio
Old 10-13-2008, 09:14 AM
treerootCO's Avatar
Determine what the operating temperature of your engine is first. If the engine is operating at 170+ then your heater should work. Use a lazer temp gauge or something other than your gauge. I cleaned out my heater core and found a solid inch of dog hair on top. The lines can be flushed with a garden hose.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 10-13-2008, 09:18 AM
treerootCO's Avatar
http://forum.ih8mud.com/40-55-series...ater-core.html
www.root45.com
TLCA #14133
Old 10-13-2008, 10:01 AM
Crash's Avatar
Crash Crash is offline
Webmaster
Sure, blame it on dogs you cat person!!
Hey, clean out your pm box - I tried to leave a message and couldn't.
Old 10-13-2008, 10:15 AM
Yeah, and you have to change your sig line cause the Ptarmigan don't look like that no mo'!
I can check my heater core for hair, but I've had it apart the last two summers/falls/winters so it should be pretty clean unless something got into it over the past couple of months. I've done the muriatic acid treatment several times on the tubes, so they should be clean as well.
I'm not understanding how my engine is overcooling since I have the t-stat in correctly with the o-ring etc. I should probably take the t-stat out and check to make sure it opens and closes. Oy
If I can't figure it out I'm just going to put cardboard in front of the radiator just for the Spooky Night Run so we have some heat!
Rising Sun Bio
Old 10-13-2008, 10:51 AM
Maybe I need to lean out the fuel a little bit? It might be running a little on the rich side...
Rising Sun Bio
Old 10-13-2008, 12:03 PM
Or maybe my cooling system needs to be burped?
Rising Sun Bio
Old 10-13-2008, 10:56 PM
i dunno, but maybe the t-stat is sticking open?? even though it's new....
does the rad hose stay cool till the truck warms up, or does it slowly warm up with the truck?
Old 10-13-2008, 10:59 PM
Don't forget pine needles and cat hair!
Old 10-14-2008, 08:22 AM
I'll pull the inlet duct to the heater core and check for obstructions and I'm going to replace the thermostat tonight (I happen to have a new spare a just bought as well that I just remembered). Has anyone ever had to double o-ring the top of the thermostat?
Rising Sun Bio
