Old 10-16-2008, 03:09 PM
Default Toyota Red in an FJ40?
Any advantage? Dave's discussion in the 3RZ-FE thread got me to thinkin'
Old 10-16-2008, 04:46 PM
I'm talking about Toyota Red coolant...
Here's Dave's comment: "Galvanic corrosion happens when dissimilar metals are immersed in an electrolyte. In the case of our engines, iron block and aluminum head bolted on (thus great electrical contact) are just waiting for the electrolyte to flow through, which we provide with coolant passages. That could be the acids left over from combustion, impurities in the water, etc. That's mainly why I think my HG went the distance, the distilled water that got flushed often. That is also why I think Toyota Red, Prestone green, whatever, is more of a non-factor if you use distilled water. Using tap water full of incident salt is probably the common denominator in HG failures, but I dunno. I do think the red stuff with phosphates works better with distilled water, where as the silicate green stuff is probably safer with water of unknown quality. The silicates are more active at preventing aluminum corrosion at the expense of wearing out pumps from the abrasion. But doing a phosphate wash or coat is a common corrosion protection technique, so I don't think Toyota Red is a bad coolant from a galvanic protection viewpoint."
This is of course in reference to the venerable 22R-E, the Cruiser head is obviously NOT aluminum, but the silicate vs. phosphate discussion is interesting, especially in reference to water pumps...
Old 10-16-2008, 07:48 PM
treerootCO's Avatar
Just keep a head gasket in the back when running red. I run black antifreeze in the 80. If you don't believe me, check the overflow. It is mostly remnants of the head gasket in there. I really enjoy the gelling you get from it as well. Smells like paraffin but I haven't confirmed that yet.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
