Old 10-26-2008, 10:28 PM
Default On Board Air (York 210)
Has anybody in the club installed a York 210 compressor to use it as an on board air compressor? If so I'm just curious about a few things....
oil control, check valves on the pressure side, unloaders, and filters on the output side...
I got one at a junk yard and am going to mount it to my vortec.
Old 10-27-2008, 10:00 AM
Hants's Avatar
Hants Hants is offline
I've got one mounted to my 1FZ-FE, but not plumbed up yet.
That's just ONE of my in-process projects.
Here's what I "know" from my research:
1. keep the oil level to the minimum to reduce spewage
2. "mod" seems sporadically helpful, at best - many report no/minor improvement
3. mount it upright (vertical)
4. unloader/check valve doesn't appear to be necessary, but can help maintain system pressure
5. coalescing filter *before* tank and other plumbing
6. few put filters on the output side (OBA mostly used to air-up); temporary one (with quick-disconnects) used where necessary
7. many also forgo adjustable regulator (cutoff switch controls max pressure)
"Wanna race?" - Bill Morgan
Old 10-28-2008, 05:56 AM
I love my York. I haven't had any problem with oil being discharged. I think I've got the mod done to reduce the oil output. My filter/seperator has a trace amount of oil in it. I did put an unloader/check valve on the output. Its probably not necessary since an unloader is usually installed to reduce startup torque when coupled to an electric motor. A regular check valve would be as good. I have had the unloader portion stick a bit and continue to dump air when the compressor is running. It might be due to the way I have it plumbed. The 2.5 gal storage tank is way in the back plumbed with a 3/8 line. I used a cheap pressure switch to control the compressor that is set to 80/100 psi. I've got a safety release valve set to 125 psi. I used an illuminated ARB switch to turn the thing on but I've got a nasty voltage back spike that'll likely blow out the light bulb soon. I tried adding a diode to stop the spike but the light still has a really bright flash when I turn it off.
The pressure switch and filter are mounted on the firewall. I used a steel braided hose to go from the compressor to the filter housing because I wanted something that would maintain strength at high underhood temps.
Old 11-12-2008, 11:46 AM
cool, thanks for the input. I got it all cleaned up and mounted during our outage. I didn't do the oil control mods and right now it seems like it pumps nice clean air... and a TON of it!
Got a pressure switch, dryer, Stainless Steel leader hose, and all kinds of other doodads to plumb it up with too. maybe a weekend project.
I am excited, this thing really moves some air!
