Notices
Old 02-23-2006, 07:38 AM
Romer Romer is offline
Default J Springs for Sale
I am posting this for T Y L E R. These are still at Slee after his upgrade. Any questions, PM him on IH8MUD.com
My J coils are 3" approx. lift as opposed to 2.5" med's. I used to run 850J/863 which came close to level, had I added a spacer up front (Mind you I had a VERY light rear .. usually almost empty tank *L*, no jump seats, no tools, no spare).
I would like $75USD for them .. they are a bit rusted near the bottom of the coils and they are 13 months old.
My paypal is zenouttazen@shaw.ca if anyone needs to know up front. I can be PM'd at Mud, and the coils can be viewed at Slee's.
Thanx!
Old 02-23-2006, 04:12 PM
FJBen's Avatar
FJBen FJBen is offline
could you run 35's with J's/Heavy? or no bueno?
TLCA#15530
96 285's OME 's ride
Old 02-23-2006, 06:58 PM
315's will probably be OK. My 35" Trexus MT's (true 35's) are tight with my J+40mm front/J rear set up. They rarely rub except on hard full stuff in the rear.
Colorado Trail Patrol
Stay on the Trail!
Old 02-23-2006, 08:26 PM
Thanks, Ken!!
Old 02-24-2006, 07:56 PM
bh4rnnr's Avatar
bh4rnnr bh4rnnr is offline
You do hard trails :lmao
4th gen Coloradoan.
Old 02-24-2006, 08:14 PM
Yup...often three times.....Once to break trail, then backwards, then third time pulling your butt through. Of course none of those trails were that tough.... :lmao watch what you step in Runner boy....
Stay on the Trail!
Old 02-24-2006, 08:50 PM
bh4rnnr's Avatar
4th gen Coloradoan.
Old 02-26-2006, 10:00 PM
Nay's Avatar
Nay Nay is offline
You could run 35's on 2.5" OME pretty easily...it's not the springs...it's the shocks. The problem with these kits is they use stock length shocks mounted in the stock positions...so there is too much up travel.
The J springs are supposed to be run with "L" shocks, which add 1" of travel...but I'd get some Bilsteins and lose the frame pin mounts with a shock adapter to space the travel down and tune it from there. I've been looking at all of these kits, and the OME stock height, OME 2.5, and OME heavy all use the same shocks (so how do you ever get bigger tires?). OME J, Slee 4", and Slee 6" all use the "L" shocks. There is major room for improvement there to fit the meats on not all that much lift...no way an 80 needs 4"+ lift for 35's with those huge wheel wells.
TYLER, who is selling the springs, is running 36" IROKs on 4" of lift. The flex sucks (up travel is limited, but shocks are still the L's), but that setup is for looks.
Nay
Old 02-27-2006, 10:09 AM
Well, all theory aside.. I bought Tyler's J springs and plan on running 35's. I'll let you know how it goes!
Old 02-27-2006, 10:54 AM
FJBen's Avatar
Are you still running stock gears? I'll be intersted in power if you do have stock gears.
TLCA#15530
HTML code is On
