View Poll Results: Which color of threadlock?
Red 4 100.00%
Blue 0 0%
Voters: 4. You may not vote on this poll
Old 10-29-2008, 10:25 PM
theboomboom's Avatar
Default Red vs. Blue
Hey all, here's my situation.
The bronco has been wanting to spit out its driveshaft lately. The last work done to it was a clutch replacement a few thousand miles ago, and in the past few hundred miles i noticed a vibration in the drivetrain. Hop under the rig, and I'm able to spin the driveshaft bolts with my finger . I cinched everything back up, under the assumption that they had not been torqued by the guy that did the clutch. A couple hundred more miles, and I'm experiencing similar symptoms. Re-check everything, and sure enough, they were loose again. Now I'm at a crossroads. There are no locking washers, or any other hardware to keep it from happening again. I plan on contacting a tech from one of the dealers nearby to find out if it needs some locking hardware. In addition to the hardware, I plan on using some threadlock. The poll at the top is whether I should use the blue, or heavy duty red. The truck has ~121k, basically stock, it's been routinely maintained, but there could be a lift in its future. Obviously, I don't want to fuss with the driveshaft bolts again untiil then, so I'm leaning towards the red. When/if it gets lifted, is it really the end of the world to try and free those bolts? Is the blue adequate in the interim?
Thanks
Rick Maestas
KD0CGE
1997 T100 4x4
Old 10-29-2008, 10:44 PM
i'm a big fan of red.
Old 11-11-2008, 06:16 PM
I'd use red - blue (esp. on older/greasier stuff) doesn't hold all that well. If the bolt threads are badly worn, replace the bolts themselves.
Old 11-12-2008, 11:52 AM
On drivelines, always use red.
KDěRCH
