Old 11-14-2008, 12:53 AM
PabloCruise's Avatar
Default Camshaft - continuation from the List
From when the forum was down...
We were talking about camshafts and then followers, and then if the lifters should rotate.
Mine looked like this when I pulled the cam to fix my oil squirter leak...
Do you think someone forgot to regrind them when rebuilding the engine?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 11-14-2008, 07:43 PM
they sure don't look like they rotate do they?
what does the cam look like?
Old 11-15-2008, 02:02 PM
No, I don't think they are rotating...
Not sure if I got a pic of the cam. It looked acceptable when I was in there.
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 11-22-2008, 10:25 PM
WOW!
Clearly that lifter (er...follower?) has not been rotating. I would take an educated guess that it wasn't so much that it had not been ground, as it had not been ground with that slight arc, or possibly that there may have been some reason it wasn't being allowed to rotate in the block.
Old 11-25-2008, 03:59 PM
Rogue Leader's Avatar
Rogue Leader Rogue Leader is offline
On the topic of cam shafts and followers, does anybody know of a shop in CO that will regrind both? I called my machine shop and several others around town and the consensus was that there were no places in Denver anymore.
TODO ES POSIBLE, NADA ES SEGUNDO
MACINNES CLAN
Well we allready got one (holy grail)
I fart in your general direction
SEAN JONES KD0DHU
Fighting fire in the last frontier.
Old 11-25-2008, 04:55 PM
Way back when I built the F in Wildrice I had Spitfire make the cam. It still is a bad mutha of an F so they must have done it right. Mac, the original owner couldn't still be alive as he was old back then but the shop is still around and still cranks out some nasty stuff so you might give 'em a call....
http://www.spitfireracingengines.com/services.html
Old 11-25-2008, 06:13 PM
That is what the tappets always look like when the cam goes flat. *shrugs*
I have a hunch that modern engine oil is to blame for your flat cam.
In Austin Healey land, we've discovered cam destruction is often related to today's oils vs yesteryear's flat tappet technology. A brand new cam, with propper assembly lube and break-in, can go flat in < 1,000 miles on a healey! The big healys sport a big ol' cast iron I-6 tractor engine very similar to the FJ40's engine.
Today's oils often have less of some critical additives. (Zinc Dialkyl DithioPhosphate in particular (ZDDP))
Here is a great link:
http://www.netbug.net/blogmichael/?p=49
KD0FDS
Stephen
Old 11-27-2008, 07:56 AM
Good to know Kev, thanks!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 11-27-2008, 07:59 AM
Wow, this looks like a great read. I'm going to have to get another cup of coffee... Sure hope my cam is not flat. I should be able to measure lift at the rockers, eh?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
