Old 11-18-2008, 01:13 PM
Nay's Avatar
Nay Nay is offline
Is the socket for the factory torx studs the "E10"? As in "external #10"?
Edit: It's an E12, but apparently you can get by with a 9mm 12 point socket.
Old 11-19-2008, 09:39 AM
I got Brian's because he's a Colorado vender.
Also, I don't think trail-mart was selling 'em at the time I got mine.
I also have ARP hub studs.
KD0FDS
Stephen
Old 11-19-2008, 09:57 AM
I also bough from Brian because he a great dude and he's not Chris Geiger!
KØUBN
Old 11-20-2008, 08:21 PM
Romer Romer is offline
Went over to Olegs because I wasn't able to get the bolt out without disassembly.
Turns out only the bolts were stripped and there was a second one that Oleg thought had an issue that needed replacing. The mangling on the bottom of the right one is from working the bolts off and on.
Oleg thinks I may have torques them too much.
The new OEM studs look much beefier. Put two in with the red loc-tite and I am golden
Thanks Oleg
Old 11-20-2008, 08:29 PM
bigbluefj's Avatar
Honorary Canuck Member
Wow we can say fubar for sure, good thing you caugth it before it was to late!!!
bigbluefj
Old 11-20-2008, 08:56 PM
Most of the damage on the right was caused by the nut and multiple nuts I tried and then finagling to try and get it off.
I was very lucky that the knuckle was fine. I like the new OEM studs. I need to get an E12 socket now. woohooo a new tool
Old 11-20-2008, 09:20 PM
bigbluefj's Avatar
New Tool Party
bigbluefj
Old 11-20-2008, 09:42 PM
Jenny Cruiser's Avatar
I put those new studs on three of my other 80s and plan on doing the same soon on the LX. They make torqueing them a cinch. I'm surprised you didn't already have those.
Old 11-21-2008, 08:29 AM
sleeoffroad's Avatar
IF those are the studs that came out, then you have an issue with the knuckle. Those threads (other than the part where you say the nuts screwed it up) look fine. Did you pull the arm to check the knuckle. I have seen plenty of them stripped.
Christo Slee
KØSLE
www.sleeoffroad.com
Old 11-21-2008, 08:43 AM
Now you give input
I took it to Oleg's and he worked on while I was at work. He said the knuckle checked out and the problem I was having was from the threads were the nuts were and the nut was spinning and not the bolt.
